2000 dodge durango, pro start 3300
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90156
Printed Date: May 16, 2026 at 5:43 PM
Topic: 2000 dodge durango, pro start 3300
Posted By: jammr
Subject: 2000 dodge durango, pro start 3300
Date Posted: February 07, 2007 at 10:49 AM
I have problems with this truck,installed Pro start3300 according to wiring diagrams it has reverse polarity,I did hook it up that way,it locks and unlocks fine but cannot get it to arm or disarm.I did connect the disarm wire to the GREEN/ orange.It has a factory keyless system.I am also told that the GREEN/ orange wire is a single lock wire and put 647(lock) and 1563(unlock) resistors.Also the alarm will go off on it's own somtimes.I am getting this car back in my shop on Saturday.Any input would be appreciated
Posted By: Twelvoltz
Date Posted: February 07, 2007 at 12:00 PM
There is no need to do a 5-wire in that truck unless you want driver's door priority unlocking. The alarm will disarm with a single pulse on the lock/unlock multiplex wire (lt GREEN/ orange) through a 1562 ohm resistor to ground double pulsing this wire will unlock the doors. The doors will lock with a pulse through a 647 ohm resistor to ground on the same wire.
