dei 1700g wiring 2006 tahoe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90210
Printed Date: April 18, 2026 at 3:33 AM
Topic: dei 1700g wiring 2006 tahoe
Posted By: tpickles326
Subject: dei 1700g wiring 2006 tahoe
Date Posted: February 08, 2007 at 8:52 AM
I need some help as to where some of the wires from the dei1700g bypass go to. I have a crimestopper cs2016 alarm that I am trying to integrate. Also could use some help with the positive lock and unlock wires from the cs 2016 unit.
Posted By: Twelvoltz
Date Posted: February 08, 2007 at 10:12 AM
What kind of help exactly do you need? Most of the wires you are going to connect will run from the remote start to the interface. The 1700G takes the analog outputs from your aftermarket system and converts them into digital information that your vehicle can understand as well as bypassing the passlock system for remote starting.
Posted By: stereoh
Date Posted: February 08, 2007 at 11:36 AM
What year and make of vehicle are you working on?
As far as help, you can always call crimestopper during their normal hours of operation(8am-4:30pm mon-friday) to get assistance with their products at 1-800-998-6880
Date Posted: February 08, 2007 at 11:50 AM
Stereoh....
tpickles326 posted "dei 1700g wiring 2006 tahoe" in the topic line
Posted By: another-kelly
Date Posted: February 08, 2007 at 12:53 PM
the 1700g uses negative lock/unlock inputs. you asking what each wire on the bypass needs to go to?
Posted By: rabenoja
Date Posted: February 09, 2007 at 7:26 PM
For what it's worth, I had a problem putting a 1700G in a 06 tahoe last week.  I installed everything correctly, as it is wired the same way as a 457G plus a keysense wire.  The 1700G just kept sending out all kinds of commands to the car...it was very unpredictable.  Anyway, I ended up taking it out and swapping it for a 457Gw.  No problems since.
Posted By: chris354
Date Posted: February 10, 2007 at 9:37 PM
I have used about 10 of the 1700g and have not had any problems with them. You only need to use the keysense wire on vehicles with the pk3 system. Did you make sure you had it set for the right platform.
