totally keyless? hands free immobilizer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90423
Printed Date: May 13, 2026 at 1:42 AM
Topic: totally keyless? hands free immobilizer
Posted By: kcfitz78
Subject: totally keyless? hands free immobilizer
Date Posted: February 13, 2007 at 10:31 AM
Crimestopper has an "Hands Free" Immobilizer SystemCS-8052.
Is this truly hands free? Walk up to your car it will disarm, unlock, and you get in "push button start on dash" and you can drive away with no key?
Anyone manufacture anything like this?
Posted By: lsondubz
Date Posted: February 13, 2007 at 11:06 AM
link? never heard of or seen this
Posted By: KarTuneMan
Date Posted: February 13, 2007 at 11:27 AM
Posted By: kcfitz78
Date Posted: February 13, 2007 at 12:25 PM
Posted By: kcfitz78
Date Posted: February 13, 2007 at 12:26 PM
https://www.crimestopper.com/
Crimestopper has an "Hands Free" Immobilizer SystemCS-8052 located on above link under keyless entry
Posted By: swerve
Date Posted: February 13, 2007 at 7:22 PM
i saw something like that on the news a few months ago. it was a chip that was imbedded in your hand or anywhere you wanted it, you just put your hand on a certain spot on the fender to get in and then you had the push button start no key, i think they wanted around a thousand bucks to install it minus the hospital fee to get it implanted. they were located somewhere in washington.
git yer swerve on!
Posted By: ghost_rider
Date Posted: February 13, 2007 at 9:32 PM
kcfitz78 wrote:
Crimestopper has an "Hands Free" Immobilizer SystemCS-8052.Is this truly hands free? Walk up to your car it will disarm, unlock, and you get in "push button start on dash" and you can drive away with no key? Anyone manufacture anything like this?
It does not work like that. The Immobilizer System CS-8052 it just a inmobilizer. You need to carry a key chain with your ingiontion keys.
The Brain module have a antena thats goes around the ignition switch and sees if you have the key chain to alow you to start the engine
  • Hands-Free Immobilizer: System Detects Transponder Pulse and Disengages Automatically
  • Automatic Arming when Leaving the Vehicle
  • Trillions of Possible Code Combinations
  • High-Security "All Black" Wire Loom
  • Emergency Override Switch
  • Easier than an Alarm: No Buttons to Push or Remote Control to Handle
  • On-Board Immobilization Circuits
  • Horn Honk / Chirp Output
  • LED Status Indicator
Date Posted: February 13, 2007 at 9:33 PM
here yopu can see a pic of this system and the key chain that you hve to carry with your keys.
https://www.crimestopper.com/images/cs-8052.jpg
Date Posted: February 13, 2007 at 9:46 PM
[QUOTE=KarTuneMan]https://www.12voltdirect.com/producti.aspx?prodid=RFKE-22
https://cgi.ebay.com/K9-Hands-Free-Car-Alarm-and-Keyless-Entry-NEW_W0QQitemZ150035692627QQcmdZViewItem [/QUOTE]
These 2 system only have a feature that is hands free for automatic access to your automobile. Automatically unlocks the doors when you are close to the car and locks them once you're further away. This mean you dont need to push the button on the transmitter to unlock or lock.
Neither of these 2 system have a feature like "push button start on dash" for drive away with no key.
If you read there features is not mention anything of push button start on dash
Ghost Rider
Date Posted: February 13, 2007 at 9:51 PM
This is the K9 info:
The new K9 Sombra uses RFID technology that will arm and lock the vehicle as you walk away, then disarm and unlock the vehicle when you return.  RFID also makes the programmable anti-carjacking system in the Sombra the most secure and easiest to use in the industry
You can make a search for K9 Hands Free Car Alarm and you will find the info.
