did a viper 5900sst remote start problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90651
Printed Date: May 15, 2026 at 4:00 PM
Topic: did a viper 5900sst remote start problem
Posted By: dcman41
Subject: did a viper 5900sst remote start problem
Date Posted: February 19, 2007 at 9:32 AM
Everything went great, i did it in a 5 spd. I hooked the neutral safety wire on the brain and everything worked great it would only start in N, not in 1st or any gear. Then i put everything back together. Now the car starts lights on the dash go on cr anks, starts for 1 second then shuts off??? I checked the shutdown diagnostics it says that its the Neutral safety wire. Maybe its a bad conection i hope?
Posted By: Twelvoltz
Date Posted: February 19, 2007 at 9:38 AM
What is the make/model/year of the vehicle? DEI specifically states that their RS units are NOT for manual transmission vehicles.
Some vehicles do have a Neutral Position Sensor that would work for you. There are several posts on the forum referencing some of these vehicles.
Posted By: profuse007
Date Posted: February 19, 2007 at 11:24 AM
If it was the NSS wire that trips, then it would not start at all. make sure all connections are wrapped.
Houston,TX
Posted By: dcman41
Date Posted: February 19, 2007 at 1:11 PM
the weird thing is that it was working i had it working and then it would start, turn over then immediatly shutdown. When i checked the diagnostics it pointed to the NSS wire shutdown
Date Posted: February 19, 2007 at 2:04 PM
Did you monitor the wire that you believe to be the correct NPS? Does this wire lose ground once the vehicle has started? As profuse stated, if that BLACK/ white does not see ground the RS will shut off/not start.
Posted By: dcman41
Date Posted: February 19, 2007 at 3:08 PM
it is definatly the correct NPS, ive confirmed it by reading the maxima factory service manual and it points right to the wire i got Pin # 22 in the ecu(GREEN / WHITE). The remote start WAS working it was working great. I think it may actually have to do with the hoodpin for some reason when i lock the doors it always says the hood is open?? Unless he unlocks and relocks the car which is weird. Any input on that ?
Posted By: peterubers
Date Posted: February 19, 2007 at 4:45 PM
Convert your hoodpin to a two pole rocker switch, see if that resolves the issue.  I know ultrastarters have an issue with programming of the r/s brain when the hoodpin is open -- could be a similar issue.
The search function is your friend.
