1996 nissan maxima door lock wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9072
Printed Date: April 18, 2026 at 10:02 PM
Topic: 1996 nissan maxima door lock wires
Posted By: SCOTT105
Subject: 1996 nissan maxima door lock wires
Date Posted: February 04, 2003 at 6:31 PM
CAN SOMEONE PLS. TELL ME AN EASIER WAY TO ACCESS THE DOORLOCK WIRES WITHOUT TAKING OFF THE DOOR PANEL TO GET TO THE SWITCH.
Posted By: PLAYER69
Date Posted: February 04, 2003 at 6:57 PM
My information says to get them at the switch in the door and it is generally right.  I don't remember the car off hand so I can't help you.  I would bet that there likely isn't a better place.
Posted By: BNLUIS
Date Posted: February 04, 2003 at 8:03 PM
There is a way to  connect it without taking door panel off. Still no easy, but it works for me everytime.
First snap the power window switch, remove the door boot. Next below the speaker in the door panel itself  there is a philip screw, remove it. Then lightly pull on the panel corner,  remove the first  door clip on the inside of the panel. There will be a hole where the door clip went into. Run a very small gauge wires truoght the hole, you should be able to reach with you fingers on the side where the boot plug in. I suggest the you tape wire so it doesn't move, now run the other side where the power window switch is you door lock wires are there. You can use  an antenna to pull the wires in the door panel, also is up too you if you want to run the wires throght the door boot. Like I said you can  use an antenna to get the wires trough. Leave plenty of slack on the wire soit stays down and won get cought in the window and use cable ties Good luck. Test wires.
Luis
Sound Waves
  POWER LOCK|lt. GREEN/ red       |-  |in drivers door at switch   |
|     POWER UNLOCK|GREEN/ YELLOW *1     |-  |in drivers door at switch
*1 Requires a double pulse
