help,02 blazer remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9098
Printed Date: April 18, 2026 at 8:19 AM
Topic: help,02 blazer remote start
Posted By: jeremy1
Subject: help,02 blazer remote start
Date Posted: February 05, 2003 at 11:05 AM
I have installed 2 different remote starters (bulldog 1300 E and a design tech delux ) in 2 different 02 S10 blazers. A bypass module has been used on each. Both vehicles seem to work  properly at first but within 48 hrs the factory passlock system is activated when attempting to use the remote. When this happens there is a ten minute delay for the BCM to reset before I can start the vehicle.  Any ideas?
Posted By: PLAYER69
Date Posted: February 05, 2003 at 11:34 AM
What kind of bypasses are you using?  It sounds like you are not adjusting them properly and the resistance is changing when it gets cold.  Try adjusting them by volage instead of resistance.  You also might want to try the PLDATAs next time.
Posted By: jeremy1
Date Posted: February 05, 2003 at 12:07 PM
I have used the bulldog model 791 which sets itself after you start the vehicle with the key upon complete instalation. I'm not sure how to adjust ba voltage or what the PLDATA is i'm kinda new at this. thanks for everyones help so far.
Posted By: jeremy1
Date Posted: February 05, 2003 at 12:08 PM
the cold having an effect does make alot of sense ..
Posted By: PLAYER69
Date Posted: February 05, 2003 at 1:01 PM
Sorry I am not familiar with BullDogs products so I can't offer much advice.  If I were you I would phone bulldog's tech support and see what they can do for you.  If you are having the same problem on 2 the chances are they have heard of it before.
Posted By: jeremy1
Date Posted: February 05, 2003 at 2:20 PM
Is there any way to bypass a passlock 2 system without a bypass module.
Posted By: Velocity Motors
Date Posted: February 05, 2003 at 3:44 PM
You can use this diagram for Passlock II bypass with two relays
Passlock II Bypass Diagram
Posted By: my12volts
Date Posted: February 05, 2003 at 4:06 PM
BULL DOG SUCKS!!!!!!!!1Try using a *DEI *AUTOPAGE OR AN *AUDIOVOX next time...
Posted By: jeremy1
Date Posted: February 06, 2003 at 8:40 AM
Jeff at velocity the relays worked great thanks .
