| Print Page | Close Window |
2007 Chevrolet Impala Alarm/Remote Start, Stereo WiringPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91145 Printed Date: April 13, 2026 at 6:08 AM Topic: 2007 Chevrolet Impala Alarm/Remote Start, Stereo Wiring Posted By: emerged Subject: 2007 Chevrolet Impala Alarm/Remote Start, Stereo Wiring Date Posted: February 28, 2007 at 10:31 PM I need the full wiring to install a sound system on the car and remote start and the unlock/lock for the car as well
thanks in advance -randy Replies: Posted By: Twelvoltz Date Posted: March 01, 2007 at 6:27 AM If you go Audiovox's website they offer all of their information for free. Just sign up for an account and you can get all the information you need. As with any wiring chart, always verify the operation of the wiring before connecting anything. Here is what they list for the 2007 Impala.
#510313: 2007 CHEVROLET IMPALA 4DR SEDAN WITH 3.5L ENGINE AND STANDARD AUDIO SYSTEM Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery RED / WHITE (+) AT RADIO HARNESS Accesory DATA THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK. Ground BLACK/ WHITE (-) AT RADIO HARNESS Illumination GRAY (+) RADIO HARNESS Dimmer PURPLE / WHITE (+) AT RADIO HARNESS Power Antenna PINK (+) AT RADIO HARNESS Amp Turn On PINK (+) AT RADIO HARNESS LF Speaker (+) TAN LF Speaker (-) GRAY RF Speaker (+) LIGHT GREEN RF Speaker (-) DARK GREEN LR Speaker (+) BROWN LR Speaker (-) YELLOW RR Speaker (+) DARK BLUE RR Speaker (-) LIGHT BLUE Amp Location UNDER REAR DECK. SUBWOOFER WIRES ARE (LEFT) DARK BLUE/WHITE(+), LIGHT GREEN/ BLACK(-) AND (RIGHT) DARK GREEN(+), LIGHT BLUE/BLACK(-) AT THE AMPLIFIER Steering Cntrls OPTIONAL THIS VEHICLE MAY BE EQUIPPED WITH ONSTARŪ AND MAY LOSE DOOR CHIME AND OTHER VEHICLE MONITORING FUNCTIONS WHEN OEM RADIO IS REPLACED. USE PROPER INTEGRATION PIECE TO MAINTAIN THESE FEATURES. Speed Cntrl OPTIONAL Radio Security YES Security WIRE COLOR POLARITY LOCATION Battery RED / WHITE (10 AMP) (+) IGNITION HARNESS ALSO IN THE BLUE BCM CONNECTOR PIN 3 Ignition 1 PINK (+) IGNITION HARNESS ALSO IN THE GREEN CONNECTOR AT THE BCM PIN 14 Starter 1 YELLOW (+) NOT USED FOR REMOTE START *SEE NOTE* ON V6 MODELS THE STARTER WIRE IS AT THE ECM BLUE PLUG PIN 26, AND ON THE V8(SS) MODEL THE STARTER WIRE IS IN THE BLACK ECM CONNECTOR PIN 22. All Door Trigger USE LATCH WIRES (-) DIODE ISOLATE YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS. Domelight Super GRAY/BLACK (+) DRIVERS KICK PANEL ALSO IN THE BCM PINK CONNECTOR PIN 1 LF Latch GRAY/BLACK (-) AT BCM PINK CONNECTOR PIN 10 RF Latch TAN/WHITE (-) AT BCM PINK CONNECTOR PIN 8 LR Latch BLUE/BLACK (-) BCM - PIN 15 RR Latch GREEN/ BLACK (-) BCM - PIN 14 Trunk Trigger ORANGE / BLACK (-) AT BCM PINK CONNECTOR PIN 12 Hood Trigger PINK/BLACK (-) AT BCM BLACK CONNECTOR PIN 17 Alarm Disarm SEE NOTES CAR MUST SEE A VALID KEY AND IGNITION 1 AT THE SAME TIME TO DISARM Alarm Arm RF ONLY Parking Lights LEFT VIOLET, RIGHT BROWN / WHITE (+) IN PASSENGERS KICK PANEL IN A HARNESS RUNNING TO THE REAR OF THE VEHICLE Low Crr Pk Lights BROWN / WHITE (-) AT THE BCM WHITE CONNECTOR PIN 8 ALSO AT THE PARKING LIGHT SWITCH Convenience WIRE COLOR POLARITY LOCATION Headlights-Lo WHITE (-) AT BCM WHITE CONNECTOR PIN 12 All Hazrd Lights TAN (-) AT THE BCM GREEN CONNECTOR PIN 19 Wipers-Lo GRAY (+) BCM BROWN CONNECTOR PIN 20 Parking Brake ORANGE / BLACK (-) BCM PINK CONNECTOR PIN 22 Trnk Release LIGHT BLUE (-) AT THE RELEASE SWITCH ALSO AT THE BCM WHITE CONNECTOR PIN 10 Remote Start WIRE COLOR POLARITY LOCATION Battery RED / WHITE (10 AMP) (+) IGNITION HARNESS ALSO IN THE BLUE BCM CONNECTOR PIN 3 Ignition 1 PINK (+) IGNITION HARNESS ALSO IN THE GREEN CONNECTOR AT THE BCM PIN 14 Ignition 2 DARK GREEN (+) IGNITION SWITCH HARNESS Accessory 1 BROWN (+) IGNITION HARNESS ALSO AT THE GREEN BCM CONNECTOR PIN 21 Starter 1 YELLOW (+) NOT USED FOR REMOTE START *SEE NOTE* ON V6 MODELS THE STARTER WIRE IS AT THE ECM BLUE PLUG PIN 26, AND ON THE V8(SS) MODEL THE STARTER WIRE IS IN THE BLACK ECM CONNECTOR PIN 22. Anti-Theft Type PK3 - TRANSPONDER Anti-Theft Descript PASS KEY III+ Key Sense WHITE (+) AT THE GREEN CONNECTOR ON THE BCM THIS IS REQUIRED FOR REMOTE START. Tachometer ANY FUEL INJECTOR (AC) USE ANY UNCOMMON WIRE AT ANY ONE INJECTOR Speed Sense BROWN (AC) AT THE ABS MODULE PIN 21 ON THE V8 MODELS THE VSS WIRE IS ORANGE AT THE GRAY PLUG AT THE ECM PIN 45. Parking Lights LEFT VIOLET, RIGHT BROWN / WHITE (+) IN PASSENGERS KICK PANEL IN A HARNESS RUNNING TO THE REAR OF THE VEHICLE Low Crr. Pk Lights BROWN / WHITE (-) AT THE BCM WHITE CONNECTOR PIN 8 ALSO AT THE PARKING LIGHT SWITCH Brake Lights LIGHT BLUE (+) AT BRAKE LIGHT SWITCH OR DRIVERS KICK PANEL ALSO AT THE BCM BROWN CONNECTOR PIN 5 Reverse Lights LIGHT GREEN (+) BCM PINK PLUG PIN 2 ALSO IN THE PASSENGERS KICK PANEL Horn TAN (-) AT STEERING COLUMN HARNESS ALSO AT THE BCM BROWN CONNECTOR PIN 18 Modules WIRE LOCATION Module 1 BCM, BODY CONTROL MODULE IS LOCATED TO THE LEFT OF THE STEERING COLUMN Module 2 ECM, ENGINE CONTROL MODULE IS LOCATED UNDER THE HOOD BEHIND THE DRIVERS SIDE HEADLIGHT IN THE AIR CLEANER ASSEMBLY. Module 3 FUSE BOX IS LOCATED AT THE END OF THE DASH ON THE PASSENGERS SIDE OF THE VEHICLE. Module 4 ABS, ANTI-LOCK BRAKE MODULE IS LOCATED UNDER THE HOOD ON THE DRIVERS SIDE REAR OF THE ENGINE COMPARTMENT Doorlocks/Windows WIRE COLOR POLARITY LOCATION Power Unlock ORANGE / BLACK (-) BCM GRAY PLUG PIN 11 PowerLock ORANGE / BLACK (-) BCM GRAY PLUG PIN 12 Driver Mtr Unlock TAN (REV) IN THE DRIVERS KICK PANEL ALSO IN A 40 PIN CONNECTOR AT THE FUSE BOX PIN J2 Driver Mtr Lock GRAY (REV) IN THE DRIVERS KICK PANEL ALSO IN A 40 PIN CONNECTOR AT THE FUSE BOX PIN J3 Pas Mtr Unlock TAN (REV) IN THE PASSENGERS KICK PANEL ALSO IN A 40 PIN CONNECTOR AT THE FUSE BOX PIN J1 LF Window Up DARK BLUE (REV) AT WINDOW SWITCH IN DRIVERS DOOR LF Window Dn BROWN (REV) AT WINDOW SWITCH IN DRIVERS DOOR RF Window Up LIGHT BLUE (REV) AT THE DRIVERS DOOR HARNESS IN THE KICK PANEL RF Window Dn TAN (REV) AT THE DRIVERS DOOR HARNESS IN THE KICK PANEL LR Window Up DARK GREEN (REV) AT THE DRIVERS DOOR HARNESS IN THE KICK PANEL LR Window Dn PURPLE (REV) AT THE DRIVERS DOOR HARNESS IN THE KICK PANEL RR Window Up LIGHT GREEN (REV) AT THE DRIVERS DOOR HARNESS IN THE KICK PANEL RR Window Dn PURPLE (REV) AT THE DRIVERS DOOR HARNESS IN THE KICK PANEL Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation. ------------- Installer, IT support, and FFL. I need less hobbies. Posted By: emerged Date Posted: March 01, 2007 at 11:46 AM thankss!!!!!
