2004 corolla le alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91274
Printed Date: April 18, 2026 at 2:00 AM
Topic: 2004 corolla le alarm
Posted By: 06_cobalt_ss_sc
Subject: 2004 corolla le alarm
Date Posted: March 04, 2007 at 9:37 PM
Hello,
I was just wondering for a couple quick tips for install on a 2004 Corolla LE. Is there an easy way to remove the panel that is covering up all of the wires below the steering column, or so I just have to reach up and around from near the pedals?
Also, does anyone have any pics for this install, just as a reference guide?
Posted By: j12v
Date Posted: March 05, 2007 at 4:05 AM
Just remove the steering column. 2 screws that face towards you when you face the wheel. You'll also need to remove the kick panel which is held in by a plastic screw type thing. I normally just pop those off, but you might wanna try un-screwing it while pulling first.
Posted By: Mike M2
Date Posted: March 05, 2007 at 6:24 AM
There are 3 screws on the column shroud, two facing the wheel and 1 underneath.
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: Chris Luongo
Date Posted: March 07, 2007 at 6:11 AM
Yeah, what the other guys said. I've done a lot of those cars. The dash doesn't come off, but it's still not a hard car.
Rock the steering wheel left to right, and remove the two black screws you see. Remove the one metal screw you'll see if you look UNDER the steering wheel.
The column cover will just snap off, but Toyota plastic scratches and gouges too easily. Turn the steering wheel to one side, hook some sort of hook tool or screwdriver into the gaps in the plastic there, and pull down. This way, if you do gouge the plastic, no one will see it.
Don't reinstall the column cover until the very last. If you leave it off during the whole installation, you'll let more light in behind the dash, and you can also reach your left arm through there if need be.
Date Posted: March 10, 2007 at 7:52 PM
Thanks for the help guys, this was my first alarm install and your advice really helped. Got it done in about 3.5 hours, not too bad for the first time I think! :)
