passlock 555l wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91322
Printed Date: April 17, 2026 at 10:35 AM
Topic: passlock 555l wiring
Posted By: cdreece
Subject: passlock 555l wiring
Date Posted: March 06, 2007 at 5:30 AM
I have a 1998 cavalier do i hook up all wires on the 555L passlock ( blue/black, violet )?  My alarm (avistart 6500) has three choices not sure which to use for what wires the choices are:
#1 Accessory Remote Start (-) Input
#2 Alarm Armed Signal (-) Output
#3 Remote Start Activated (-) Output
The 2 wires in question from the passlock 555L are:
#1   Blue/Black (-) Status Input (instructions say) connect this wire to the (-) status output of the directed remote start system
#2   Violet (-) Input from Starter Relay (instructions say)connect this wire to the (-) starter output of the remote start system.This is the violet ribbon harness wire of the pre wired relay pack.
Never done a passlock before got the rest of the alarm/passlock done just waiting for some input for these wires. Car has Passlock 1  Thanks For Any Help
Posted By: rudydapimp
Date Posted: March 06, 2007 at 7:48 AM
The wires that you need are as follows
Black - connected to passlock ground
BLACK / YELLOW - BCM side of passlock wire
Yellow - Ignition side of passlock wire
Red 12v Constant
Pink Ignition input
Blue/Black Connect to Gray/Black wire
Posted By: cdreece
Date Posted: March 06, 2007 at 12:04 PM
 thanks
Posted By: JWorm
Date Posted: March 06, 2007 at 12:48 PM
I had an Avistart a few years back. I don't remember if it had a (-) when crankin output. If it does, it would be a lot easier. I'll assume it doesn't.
You still need to connect the violet wire to a wire that provides ground only when cranking. You need to split the gray/black wire with diodes. Connect one wire to the blue/black of the 555L. The other wire will need to trigger a relay:
86 - (+) starter wire in car
85 - gray/black
87 - ground
30 - violet of 555L
Date Posted: March 06, 2007 at 1:18 PM
oh yea, sorry, forgot that the Cav has Passlock I.  THought it made the change over to Passlock II.
