remote start 2001 silverado
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91449
Printed Date: March 24, 2026 at 6:05 PM
Topic: remote start 2001 silverado
Posted By: garedora
Subject: remote start 2001 silverado
Date Posted: March 08, 2007 at 10:03 PM
I have a sr6000 pro security alarm with a 556L GM passlock module. I have both ignition wires hooked up Pink ign 1 and white Ign#2. Now I did forget to hook up the 2nd ign White wire before I installed the passlock mod, and I notice the auto tranny wont shift normal. The tranny shift normal just useing the key. My question is do I need to reset the alarm or the passlock ? Or am I missing something else. Thanks in advance.
2001 Siverado 2500 6.0 4wd
Posted By: tbjoe
Date Posted: March 09, 2007 at 2:13 AM
You need to hook up the orange wire in the ignition harness as the third ignition. Make sure brown is hooked up as accessory. You shouldn't have to reprogram your module since it is starting the truck.
Posted By: garedora
Date Posted: March 09, 2007 at 7:04 PM
when I try to hook up the orange wire as an ign all the dash lights come on and door chime. The brown wire doesnt seem to work as an acc wire
Posted By: Velocity Motors
Date Posted: March 09, 2007 at 8:08 PM
ORANGE wire is ACC and BROWN is not needed for remote start. You need to have the WHITE wire hooke dup as a 2nd IGN and the PINK wire as well.
------------- Jeff
Posted By: garedora
Date Posted: March 09, 2007 at 11:24 PM
I did hook up both the pink Ign wire and the white ign wire and I still get the tranny issue. Any other idea what might cause this issue? It only does it when useing the remote start. When useing the key every thing works normal.
Date Posted: March 09, 2007 at 11:45 PM
Test to make sure that the wire going to the WHITE 2nd IGN wire is in fact receiving 12 volts when under remote start. Also, how long did you travel while under remote start with no 2nd IGN wire being powered ?
------------- Jeff
Posted By: tbjoe
Date Posted: March 10, 2007 at 1:22 AM
One of the programs I use for my diagrams lists the orange wire as ignition 3. The other lists it as acc. I had this same issue with a 2001 Monte Carlo a couple of years ago. It turned out that I had the wrong tach wire hooked up. Disconnect the tach wire and try it.
Posted By: garedora
Date Posted: March 10, 2007 at 8:04 AM
I will double check the wire for the 2nd ign but im pretty sure it had 12 volts when under remote start. If not what do I need to to. Also, I only drove about 1-2 miles and never went above 40 mph.
