99 deville alarm sleep problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92184
Printed Date: May 09, 2026 at 2:38 PM
Topic: 99 deville alarm sleep problem
Posted By: hessdawg
Subject: 99 deville alarm sleep problem
Date Posted: March 27, 2007 at 11:26 AM
hey i have a 99 cadillac deville i put a dei viper 350hv alarm into.we also used a dei 451m relay and tagged the RED / black and orange black for lock and unlock, and the light green for disarm. the alarn will worn fine for intermitantly but after a while the car will shut down and the alarm will sound but the locks wont work and trunk won't pop.already swapped the brain out and tripple check wiring. anybody ever heard of this ???? called dei tech no help. thank in advance ------------- hessdawg out
Posted By: streetdream
Date Posted: March 27, 2007 at 9:13 PM
Does the factory alarm get all screwy or the aftermarket one? I have seen this on a remote start once where the factory alarm would go off as soon as you literally touched the car.
------------- MECP First Class
Bay Manager
Posted By: hessdawg
Date Posted: March 28, 2007 at 11:13 AM
haven't heard the factory alarm go off att all but some times when we hit the arm botton it will unlock the door and when you disarm it will lock the doors. never seen any thing like this
Posted By: KarTuneMan
Date Posted: March 30, 2007 at 8:06 AM
So...some times the lock and arm work as they should.....then sometimes they work in reverse? That is odd. Has the factory security EVER malfunctioned? Try using just the factory stuff for a while and see if the problem persists. Is the 451 being used correctly? I am not a fan of any "prewired" relay packs. I like to do it myself as to be sure it's done properly -------------
Date Posted: March 30, 2007 at 8:35 AM
You shouldn't even need to use a relay pack on that vehicle. Sounds like you have possibly the wires backwards?
Bay Manager
Posted By: hessdawg
Date Posted: March 30, 2007 at 12:49 PM
car comes in today i thing i'll pull the alarm and wiring out and start all over. been doing this for 7 years now and i have never seen this happen. ------------- hessdawg out
Date Posted: March 31, 2007 at 12:38 AM
How do you do the door locks on this car without relays? -------------
Posted By: hessdawg
Date Posted: April 02, 2007 at 12:29 PM
just with the dei 500ma rev polarity wires. had it wired like this firs then put the 451m relay pac in. worked on it friday and had it all working great. kept it overnight to see if it would sleep. came in saterday morning still working fine. came in monday after sitting all day sunday, and now it chirps but no lock moving up or down.
Date Posted: April 02, 2007 at 1:16 PM
This makes no sense....at least to me? The DEI 500ma rev.polarity wires? Does DEI do such a thing? If they have "rev. polarity wires" wouldn't they be connected to internal relays? The more I read, the more confused I become...... Does anyone have a postable install manual for this viper...at least the page that talks aboput door lock options? Anyways...what are you using from the viper to "disarm" the factory stuff? -------------
Posted By: hessdawg
Date Posted: April 04, 2007 at 11:35 AM
the viper 350hv has lock and unlock out puts on the brain that are thin blue and green. the blue will output - unlock or +lock. green will pulse - lock or +unlock all at 500ma. you can unplug this 3 pin plug and plug in a 451m relay pack for stronger current door locks
