2002 Durango remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9233
Printed Date: May 11, 2026 at 2:07 AM
Topic: 2002 Durango remote start
Posted By: Dream Theater
Subject: 2002 Durango remote start
Date Posted: February 08, 2003 at 4:10 PM
Installing a remote start with keyless entry in a 2002 Dodge Durango and need a wiring diagram for this application.Can you tell me if there are any special notes before I begin.I installed the same remote start in a Dodge ram 96 and it required 5 wire system for the door locks and I installed the same in a 2001 4 Runner and that needed isolation of specific wires, does any of this apply to the Durango or is there something different in it's application. Thank you for your time it will help me to prepare!
Thank You!
Posted By: jayts95
Date Posted: February 08, 2003 at 6:58 PM
|              12V|pnk/blk & RED / lt blu|+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|blue                |+  |ignition harness            |
|  SECOND IGNITION|GREEN/ red    (18 ga)|+  |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
| SECOND ACCESSORY|green               |+  |ignition harness            |
|       POWER LOCK|WHITE/ green         |*1 |conn. 2, pin 10 @ CTM *2    |
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|ORANGE / black        |   |conn. 2, pin 4 @ CTM *2     |
|     UNLOCK MOTOR|blue                |   |conn. 2, pin 6 @ CTM *2     |
|    DISARM DEFEAT|pink/black          |   |conn. 2, pin 5 @ CTM *2     |
| PARKING LIGHTS +|BLACK / YELLOW        |   |headlight switch            |
| PARKING LIGHTS -|RED / yellow          |   |conn. 1, pin 4 @ CTM *2     |
|       HEADLIGHTS|lt. GREEN/ orange    |-  |headlight switch            |
|     DOOR TRIGGER|*3                  |-  |CTM *2                      |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tan/black           |-  |conn. 2, pin 7 @ CTM *2     |
|  FCTRY ALARM ARM|lt. GREEN/ orange    |*4 |conn. 2, pin 14 @ CTM *2    |
|FCTRY ALRM DISARM|same wire           |   |                            |
|       TACHOMETER|*5                  |   |ignition coil               |
|      SPEED SENSE|WHITE/ orange or blue|   |conn. 2, pin 27 @ PCM *6    |
|       BRAKE WIRE|WHITE/ tan           |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |-  |steering column or CTM *2   |
|           WIPERS|purple(L), RED / gry(H|+  |steering column             |
|  LF WINDOW UP/DN|lt. blue - white    |A  |driver window switch        |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |driver kick panel           |
|  LR WINDOW UP/DN|blu/wht - RED / blk   |A  |driver kick panel           |
|  RR WINDOW UP/DN|gry/blk - grn/wht   |A  |driver kick panel           |
|        RADIO 12V|pink                |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|RED / white           |+  |radio                       |
| RADIO ILLUMINATE|white               |+  |radio                       |
|       LF SPEAKER|lt grn/pu-lt grn/grn|   |radio                       |
|       RF SPEAKER|lt blu/pu-lt blu/blk|   |radio                       |
|       LR SPEAKER|wht/red - wht/blk   |   |radio                       |
|       RR SPEAKER|tan/pur - tan/blk   |   |radio                       |
Notes:
NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U.  *1 Lock is negative trigger thru a 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.  *2 The Central Timer Module is in the driver kick panel.  *3 The driver door trigger is tan in connector 2, pin 15. The passenger door trigger (and rears) is tan/red in connector 2, pin 13. Use both and diode isolate each. See directfax document #1076 for wiring information.  *4 Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger thru a 1565 ohm resistor. MUST use relays. This wire will also lock the doors, and it will unlock with a double pulse.  *5 On the 5.9L models use BLACK/ gray at the ignition coil. The 4.7L models have an ignition coil for each cylinder, use the wires that is NOT GREEN/ orange at one of the coils.  *6 The Powertrain Control Module is on the passenger fender.
