03 explorer xk4 pkford module wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92350
Printed Date: April 05, 2026 at 3:59 PM
Topic: 03 explorer xk4 pkford module wiring
Posted By: bruc007
Subject: 03 explorer xk4 pkford module wiring
Date Posted: March 31, 2007 at 8:17 PM
Hi guys,I picked up a Ford bypass module xk4-pkford, and need some wiring clarification .the instruction sheet was incomplete so I downloaded it from their website.My main question is the brown wire from the module says "GWR in". What exactly does that mean. I know green goes to ecm tx, pink goes to ecm rx,red to battery,black to ground..The plug on the vehicle has 4 pins
1 = ground
2 = ignition
3 = rx
4 = tx
Any help would be great
Thanks Bruce
Posted By: mikvot
Date Posted: March 31, 2007 at 10:29 PM
I dont have the exact colors, but i'm looking at a manual for the same kind of bypass. One of the 4 wires is gonna show 12v with ignition on(pin1).......the wire next to that (pin2)will be the ground. (pin3) is tx(data) pin 4 is Rx(data). The gwr stands for ground while running....this needs to go to the (-) status ouput of your remote start. This is what turns the module on before the car remote starts.
Posted By: bruc007
Date Posted: March 31, 2007 at 11:38 PM
Thanks for your help.I downloaded complete instructions including programming from the website and it seems to be no problem
