2002 ford explorer ignition override
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92438
Printed Date: April 06, 2026 at 11:25 PM
Topic: 2002 ford explorer ignition override
Posted By: borborpa
Subject: 2002 ford explorer ignition override
Date Posted: April 02, 2007 at 2:20 PM
Hello.  I've purchased a Able2 Ignition Override - to keep the vehicle running while I'm not near it.  I have the wiring diagram for my 2002 Ford Explorer Limited, but I have a question.  The Override module has 4 connections for Ignition, but says you may not use them all.  I'm guessing I only need two, the ignition wire and the acc wire, to keep it running.  Does this sound correct?
Posted By: peterubers
Date Posted: April 02, 2007 at 3:44 PM
https://able2products.com/PDFs/05_0915_Instructions.pdf   Here is the manual --
You have 4 or 5 ignition output wires... this allows for cars with multiple ignition and accessory wires.
You are correct, you only need to use as many wires as your car needs (in this case only two wires)
12 VOLT CONSTANT  YELLOW (+)   IGNITION SWITCH HARNESS
 STARTER RED (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 RED / LIGHT GREEN (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 GREEN/ LIGHT GREEN (+)  IGNITION SWITCH HARNESS
The search function is your friend.
Date Posted: April 02, 2007 at 3:47 PM
Just be sure and properly tape off the other two or three unused wires as these will be HOT (i.e. carrying 12 volts) when you're in ignition override mode.
According the manual I linked you to .. there are four inputs, and 5 outputs.
