viper 5500 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92507
Printed Date: April 08, 2026 at 2:42 AM
Topic: viper 5500 remote start
Posted By: scrat_82
Subject: viper 5500 remote start
Date Posted: April 04, 2007 at 10:00 AM
i need to know how to adjust the crank time on the viper 5500 system. it just doesnt crank long enough and i have to try it 3 times with the remote to get it to work.
thanks chris
Posted By: kgerry
Date Posted: April 04, 2007 at 11:29 AM
you can adjust it thru the programming menu... but are you sure that you have everything hooked up correctly? because i have very, very rarely EVER had to adjust the crank time on a DEI piece.....
do you have it programmed for tach or voltage?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: enice
Date Posted: April 10, 2007 at 10:16 AM
I agree.  First you have to see if your vehicle has an immobilizer.  This will cause the car to keep cranking and not let the vehicle fully turn on.  What type of vehicle is it?
