Mitsubishi Eclipse GS 99' remote start wiring?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9254
Printed Date: May 10, 2026 at 3:30 PM
Topic: Mitsubishi Eclipse GS 99' remote start wiring?
Posted By: si_junior
Subject: Mitsubishi Eclipse GS 99' remote start wiring?
Date Posted: February 09, 2003 at 1:32 AM
Is anybody got the wiring for the security and remote start wiring for a manual transmission Mitsubishi Eclipse GS 1999?  Thanks...posted_image
Posted By: Velocity Motors
Date Posted: February 09, 2003 at 8:05 AM
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ red           |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|        ACCESSORY|blue/black          |+  |ignition harness            |
|       POWER LOCK|RED / blue            |-  |*1                          |
|     POWER UNLOCK|BROWN / red           |-  |*1                          |
|       LOCK MOTOR|blue/black          |   |drivers door harness        |
|     UNLOCK MOTOR|blue/red            |   |drivers door harness        |
|    DISARM DEFEAT|blue/red            |   |passengers door harness     |
| PARKING LIGHTS +|GREEN / WHITE         |   |in drivers kick             |
| PARKING LIGHTS -|GREEN / WHITE   22 awg|   |steering column *2          |
|       HEADLIGHTS|red                 |-  |steering column             |
|     DOOR TRIGGER|RED / green           |-  |in drivers kick *3          |
| DOME SUPERVISION|*4                  |-  |*4                          |
|  TRUNK/HATCH PIN|RED / green           |-  |driver kick panel *3        |
|         HOOD PIN|blue/black          |-  |fuse box                    |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|GREEN / WHITE         |-  |drivers door harness        |
|       TACHOMETER|white               |   |instument cluster or PCM *5 |
|      SPEED SENSE|yellow/white        |   |data link connector *6      |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|GREEN/ black         |-  |steering column             |
|           WIPERS|blu/org(L),blu/blk(H|+  |steering column             |
|  LF WINDOW UP/DN|grn/red - grn/black |A  |in drivers door             |
|  RF WINDOW UP/DN|brn/yel - grn / YELLOW|A  |in drivers door or dkp      |
Notes:
*1 Located behind the glove box in a harness.  To unlock only the drivers door on models with keyless entry. Use BROWN / blue negative(-) trigger at the relays behind the radio.  *2 Found in a gray 20-pin connector.  *3 To avoid the dome light delay use RED / white(-) at the door open indicator at the instrument cluster.  The RED / white will also catch the rear hatch.  *4 Use the RED / green door trigger wire for dome light supervision.  *5 The PCM is located on the drivers side of the engine compartment or behind the center of the dash depending on motor.    *6 The data link connector is under the driver side dash.
