remote starter, alarm, 2001 ford windstar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92553
Printed Date: April 08, 2026 at 8:04 PM
Topic: remote starter, alarm, 2001 ford windstar
Posted By: wawi0069
Subject: remote starter, alarm, 2001 ford windstar
Date Posted: April 05, 2007 at 12:18 AM
my dad's 2001 ford windstar have a rattler 300 or DEI 431R installed professionally. the problem is i want to install a bulldog deluxe 500 remote starter... i just don't know how to wire them properly. i mean i can wire the starter, crank, constant 12v the thing is i don't want to remove the rattler. i still want the alarm to operates. and it is possible to use the bulldog remote as a main control? like armed and disarmed the rattler. thanks for the help guys!
Posted By: wawi0069
Date Posted: April 05, 2007 at 6:20 AM
alright... this are the manuals... so that you can understand what i mean and help me... thank you...
bulldog deluxe 500 https://www.bulldogsecurity.com/bdnew/newsite/pictures/pdfs/DELUXE%20500%20INSTALL%20MANUAL.pdf
rattler 300 (DEI 431R) https://www.directed.com/guides/manuals/ig/rattler/N431R.pdf
plsss help me out guys... thanks again...
Posted By: tonyberg
Date Posted: April 05, 2007 at 1:43 PM
Theres no way to combine the 2 units, your best bet is to take out the rattler piece and find a quality security system that incorporates a remote starter. this is by far the best method with little to no headaches.
Posted By: Hymer
Date Posted: April 05, 2007 at 3:32 PM
Absolutely, why combine 2 terds? you just get one big pile with a bad smell and a big headache. Spend your money on a decent combined unit that will function properly from day 1. Trying to interface 2 different mfgs just doesnt always work right. I didn't look at you links but Im sure the bulldog wont do it. [theyr going under anyway why put one of their units in???] , off the rattler [aux out put ch 3] to activate the rs unit, but a bullpuppie wont activate that way , and Im pretty sure a rattler wont have a wire to pulse to disarm it.. SOL. If ya get a DEI unit and you HAVE an aux output third channel, then you could activate a stand alone remote start the is designed to be added on to an alarm. Like stated, a headach!
------------- Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Posted By: wawi0069
Date Posted: April 07, 2007 at 12:12 AM
ahhh... ok... well forget about it... thanks a lot guys!
