2000 Accord
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9265
Printed Date: May 10, 2026 at 1:11 PM
Topic: 2000 Accord
Posted By: Htownmalu
Subject: 2000 Accord
Date Posted: February 09, 2003 at 9:08 AM
Hello i just finished installing a Viper 790xv on my car.  Along with it i installed pop trunk and the front two window mogulator.  After installing it when i put up my windows with my remote, its kinda lagging.  Even when the car is running, and i put it down its laggin also.  Do yall have a solution to that or is that normal.  Thanks
Posted By: Velocity Motors
Date Posted: February 09, 2003 at 9:44 AM
Make sure that the ground and the power for the module is solid and soldered. If there is resistance in the wire, it will affect the modules performance.
Posted By: BNLUIS
Date Posted: February 09, 2003 at 10:52 AM
Also if you use a DEI window roll up, down module. You can adjust the resistance on the dipswitches in the module. it might help,  If not try what Jeff says.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
