ungo sr6000
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92734
Printed Date: April 11, 2026 at 3:05 PM
Topic: ungo sr6000
Posted By: wrcknkrw
Subject: ungo sr6000
Date Posted: April 09, 2007 at 10:24 AM
have 2004 chevy 3500 with diesel and ungo sr6000.  had installed at pro shop and everything worked great for about 6 months. everything stills works except remote start.  it'll go through the start sequence and die just after the engine starts.  i can't find a toggle switch anywhere.  thanks
04 silverado 3500 dmax/alli 4x4
Posted By: one_bad_jap
Date Posted: April 10, 2007 at 7:12 PM
Check the shutdown diagnostics.
1) with the ignition off, press and hold the valet/programming button
2) turn the ignition on and then back off while holding the valet/programming button
3) release the valet/programming button
4) press and release the valet/programming button. the LED will report the last shutdown for one minue or until the ignition is turned on.
LED Flashes                                        Shutdown Mode
one                                                       timed out
two                                                       over-rev shutdown
three                                                    low or no RPM
four                                                       transmitter shutdown (or optional push-button)
six                                                         (-) shutdown or (+) shutdown
seven                                                   (-) neutral safety shutdown
eight                                                     wait-to-start timed out
Reprogramming the tach signal
1) start the vehicle
2) press and hold the valet/programming button until the LED comes on solid.
3) release the valet/programming button and turn off the ignition
If the LED does not come on, then double check the connection for the tach reference.
