power windows won’t rull up/down
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92835
Printed Date: May 06, 2026 at 8:18 PM
Topic: power windows won’t rull up/down
Posted By: landontc
Subject: power windows won’t rull up/down
Date Posted: April 11, 2007 at 7:22 PM
Installing a 791xv.
Have made all of the heavy guage wire connections and the door lock connections and a couple other connections.
My power windows don't work now at all. Power locks work fine, but windows don't move.
Any ideas?
I'm pretty sure it's not a fuse.
Posted By: pitoaudiovisual
Date Posted: April 12, 2007 at 8:41 AM
if you checked the fuses make sure there is nothing disconnected .. does the window try to move .. do you hear the motor. maybe the window relay went bad.. check all connections .. what year is the car and what kind of car..
Confidence is the key to any project!!
Posted By: landontc
Date Posted: April 12, 2007 at 11:42 AM
It's a 2001 ford explorer sport.
I got so frustrated with everything that I disconnectd my wires that connected to my starter, ignition, etc.
Once I hooked my starter wire back together, everything started working.
No idea what caused it.
Posted By: peterubers
Date Posted: April 12, 2007 at 11:45 AM
does your remote starter work now?
The search function is your friend.
