which bypass module for 05 gmc canyon
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92849
Printed Date: May 06, 2026 at 11:46 PM
Topic: which bypass module for 05 gmc canyon
Posted By: nava94
Subject: which bypass module for 05 gmc canyon
Date Posted: April 11, 2007 at 11:12 PM
Hey guys for the 2005 gmc canyon I'm installing a 564t remote start/alarm, will the 556L work or will it be better to just do the two relay set up?First time putting my hands on this kind of truck , on the schematic I do not see a bypass module that's available for this truck but I read you could use the 556L or the two relay set up. On the relay set up document 1603 the first relay shows the purple wire from the relay pack goes to 86, and the second relay shows an ignition wire with a diode to 86, is that ignition wire for the second relay from the relay pack too?If this is correct isn't the second ignition wire from the relay pack go to the second relay since the WHITE/ blue to white and WHITE/ yellow to WHITE/ black from the truck perform keysense,second ignition,starter,and passlock? All the connections from the remote start  relay pack I need to connect is the 3 thick 12volt wires, ignition, and accessory?Am I on the right track or way off? thanks in advance.
Posted By: enice
Date Posted: April 11, 2007 at 11:34 PM
Try using the PASSLOCK-SL.  You may look at the actual install manual and decide for yourself if you would feel comfortable installing it.  The link to this is https://bypasskits.fortinautoradio.com/en/products/bypass_kits/passlock-sl/?year=2005&make=11&model=2930
Posted By: pitoaudiovisual
Date Posted: April 12, 2007 at 8:38 AM
i always use the  556L and its easier than doing the relay set up but its cheaper to do the relay set up your self..
Confidence is the key to any project!!
Posted By: Twelvoltz
Date Posted: April 12, 2007 at 9:34 AM
DEI is no longer listing the 556L as a viable bypass option on directechs.com. I think there was a longevity issue with the 556L in the Canyon/Ion platform. Instead they only list document 1603. So, it is either the Fortin/bypasskit piece listed earlier or the document but not the 556L.
Posted By: kgerry
Date Posted: April 12, 2007 at 5:21 PM
i use the PLJX usually on these with no issues....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
