remote start 1998 s10
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93069
Printed Date: March 28, 2026 at 7:29 PM
Topic: remote start 1998 s10
Posted By: atomicspark
Subject: remote start 1998 s10
Date Posted: April 17, 2007 at 9:35 PM
hello i was wondering if you guys could help me out. i have a 98 Chevy s10 and i purchased a clifford matrix 50.5x and i installed it along with the dei 555l... however it will crank but then die. my question is on the 555l, when i installed it to the specs in the installers manual and learned the code it still wont start. On the 3 pin harness that i wired into, there seems to be some kind of an IC or a chip that is attached to all 3 of these wires. Do i need to wire before or after this black IC or chip or does it matter.
Any input would be gladly appreciated thanks, atomicspark
Posted By: pitoaudiovisual
Date Posted: April 17, 2007 at 10:24 PM
is the theft light still flashing. i install them right after the black plug.
Confidence is the key to any project!!
Date Posted: April 17, 2007 at 10:29 PM
also make sure you did passlock 2 and not 1
Date Posted: April 18, 2007 at 10:16 AM
the theft light isnt flashing at all and im sure that i did passlock 2
Date Posted: April 18, 2007 at 10:18 AM
and right after the black plug? in between the 3 pin connector and the black plug or inbetween the black plug and the BCM
Posted By: tonyberg
Date Posted: April 18, 2007 at 10:39 AM
WHere you install the 555L is wholelly irrelevant the things to make sure of are :  1.  The pink wire is hooked to ignition .  2. The yellow and BLACK / YELLOW are not reversed.  3. The ground is connected to the passlock ground reference wire for the most accurate learning.   4.  Make sure you have the GWR hooked up to the right wire and that the wire is programmed as a GWR or status output.
Date Posted: April 19, 2007 at 12:15 PM
Ok I will give it a try tonight... But then what the crap is that black box that is inbetween the 3 pin connector and the BCM
Date Posted: April 20, 2007 at 3:35 PM
Ok heres the deal i have checked all of the wiring to make sure that its correct, the car cranks but dies, the car will start with the key, the theft light is not flashing, and the only thing i can think of is that i cannot learn the tach... could that be it?
Posted By: rudydapimp
Date Posted: April 20, 2007 at 9:25 PM
will it start and run with the key in the ignition???
Posted By: another-kelly
Date Posted: April 20, 2007 at 11:05 PM
why can't you learn tach? you tried setting it to voltage sense for remote start? if no tach is learned and it's programmed for tach, then it will only crank, not start
Date Posted: April 22, 2007 at 5:49 PM
Ok, so i couldnt get it to start when i had the tach wire hooked up to the alarm... so i hooked it up to the fuel injector control wire that comes out of my ECM. Then it learned the tach and i have remote start. Thanks for all of your help
