2006 tiburon door locks and 451m
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93079
Printed Date: March 28, 2026 at 9:04 PM
Topic: 2006 tiburon door locks and 451m
Posted By: johnblaze94
Subject: 2006 tiburon door locks and 451m
Date Posted: April 18, 2007 at 5:04 AM
Im having trouble determining the correct way to wire up the dei 451m to my door locks. Any help would be appreciated
Posted By: Twelvoltz
Date Posted: April 18, 2007 at 6:53 AM
According to DEI your system is a type F which means there is one wire that controls lock and unlock. They list this note too:
"HYUNDAI, TIBURON, 2006, Power Lock
The yellow wire will test when moving the driver lock knob, the blue wire will test when moving the passenger lock knob.
The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash."
If this wire sees a ground pulse it locks the doors and if it sees nothing it unlocks the doors. Take a look at page 8 of this document and see if it doesn't clear it up for you.
