Car Alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=931
Printed Date: March 30, 2026 at 5:57 AM
Topic: Car Alarm
Posted By: gq_40
Subject: Car Alarm
Date Posted: May 24, 2002 at 4:23 PM
I was looking at the wiring diagram and it tells what color wires goes where, but does it mean that I have to tie into the fuse box or the wires in the back?  Please let me know.
Charles
Posted By: Velocity Motors
Date Posted: May 24, 2002 at 5:20 PM
You have to look at the wire location and that is where you need to attach the alarm wires to .
Posted By: gq_40
Date Posted: May 24, 2002 at 11:05 PM
Is there anything special I need to know?  I have a 95 Honda Accord and no clue of where to start.  I need a diagram to go by for "Dummies".  Is there such a thing?
Charles
Date Posted: May 25, 2002 at 9:10 AM
Professional isntalation is highly recommended for alarm/remote starter installations, but here is a diagram for your Accord. There is no special bypass that you will need, all connections are straight forward, but MAKE SURE YOU USE A DMM to double check all circuits before attempting to connect a wire to the remote unit.
Honda
Accord
1994-1995
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK / YELLOW
Ignition #2:
YELLOW
Ignition  #3:
N/A
Accessory:
WHITE/ BLACK
Brake  Light:
GREEN / WHITE
(+) AT BRAKE LIGHT SWITCH
Tach  Signal:
BLUE OR TAN/BLUE
TACH TEST CONN.-DRV ENG COMPARTMENT
Parking Lights:
RED / BLACK (+)
ABOVE DRV KICK-20 PIN BLUE CONN PIN 6
Headlights:
RED / BLACK
(+) AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
Honda
Accord
1994-1995
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
IGNITION SWITCH HARNESS(FUSED 50 AMP)
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
BLACK/ WHITE/ SILVER (-)
GRAY MOLEX TO RT. OF STEERING COLUMN
OEM Horn:
LIGHT GREEN/ BLUE (-)
IN IGNITION SWITCH HARNESS
Power  Lock:
BLACK/ WHITE
2 PIN PLUG, TAPED TO WIRING
Power  Unlock:
ORANGE
HARNNESS ABOVE FUSE BOX *
Trunk  Release:
N/A
Alarm  Input Wire:
Notes:
* Negative Pulse Door Lock
