viper 560xv remote start problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93202
Printed Date: March 30, 2026 at 3:13 PM
Topic: viper 560xv remote start problems
Posted By: dspjm28
Subject: viper 560xv remote start problems
Date Posted: April 21, 2007 at 7:52 PM
I have a 2004 Hyundai Sonata and trying to install a viper 560xv.All features work except the remote start.when I try to remote start nothing happens.I am from Jamaica so everything on my sonata is on the opposite side of the car but all wires match U.S. model.No wire on the secondary harness (H2)is connected as I do not know what to connect to and what is the remote start activation input(WHITE/ blue wire)?.Normally when my key is removed all parking lights including headlamps go out.How will I get these to flash when the key is not in to activate them?sorry for the long post but I am new.Thank you all in advance
Posted By: enice
Date Posted: April 21, 2007 at 9:03 PM
Did you connect the BLACK/ white wire to ground? That needs to be grounded to be able to activate. In addition to that you also have to connect your tach wire which is the PURPLE / white(double check) wire.  Also check to see if your car has an immobilizer.  As soon as you have those wires connected and the tach programmed(have one door open, turn car on, and hold the valet switch for 5 secs--you will hear a click if done correct).  Last after all that is done try to turn on with remote.  If the car turns but immediately shuts down then insert the key in the cylinder(dont turn just keep in cylinder) and remote start.  If it does remote start with key inside and not with key outside then you have an immobilizer that needs to be bypassed.  Good Luck
Posted By: dspjm28
Date Posted: April 21, 2007 at 9:10 PM
Thank you.I will try this first thing in the morning.Will my park lights flash although theyrequire the key in the ignition to come on under normal circumstances?
Posted By: enice
Date Posted: April 21, 2007 at 9:23 PM
When remote started your parking lights(if connected) will flash.  Just as when your lock your door.  You will see them once for lock and flash twice for unlock.  When remote started the will flash in steady pace.  For your car you would connect the white wire that has an in line fuse to purple wire.  Also you have to trigger the key sense wire so that your factory alarm wont go off when remote started.  The key sense is either RED / blue or light green and is (+).  Just make you always use multimeter to double check connections.
Posted By: dspjm28
Date Posted: April 21, 2007 at 9:52 PM
The trunk release is a button on the drivers door.will I need a relay to have this work via alrm remote?
Posted By: enice
Date Posted: April 21, 2007 at 10:01 PM
yes you would use the RED / white wire to control it on the alarm harness.  It is a negative pulse,connect to green wire in the ETACM (Electronic Time and Alarm Control Module) which is attached to the fuse box below the fuses.  I think you dont really need a relay unless it doesnt have a strong signal.  try direct to that wire and it should work.  if it doesnt then use the relay
Posted By: dspjm28
Date Posted: April 21, 2007 at 10:08 PM
Thank you. You have helped alot.I will post my progress tomorrow .
Posted By: dspjm28
Date Posted: April 22, 2007 at 9:13 AM
Car now starts and shuts down immediately with remote start.Tried key and still now luck.Found a blue wire in instrument cluster with varyingn ac voltage.Tried tach learning but led does not light.
Posted By: enice
Date Posted: April 22, 2007 at 9:48 AM
If car started then you dont need a bypass.  If car cranked but did not start then you need bypass.  Seems like you dont need a bypass.  To find a tach signal go to the engine.  Go to a fuel injector wire.  It usually is a 2 pin plug.  You might see them in series. You will see one wire that has the same color on those plugs.  The one that is different is the wire.  Just double check.  Try to fnd the wire there.  Also Ive checked for the tach signal and it shows that its a WHITE wire not blue.
Posted By: dspjm28
Date Posted: April 22, 2007 at 10:16 AM
I got the car to start now .My tach signal wire is green with black stripe so there is a differnce in wire color.I was connecting the incorrect wire.your info helped alot.I am still unable to locate wires for the park light flash and trunk release.I am working on those now.
Posted By: enice
Date Posted: April 22, 2007 at 10:27 AM
You can also go to the light switch and directly to the door for the trunk release.  Take door off and check which wire in the trunk switch is the receiving a pulse when opening the trunk with the button and tap into there.  It should be a GREEN/ black wire in the kick panel.  And for the parking lights go to the swith and find a light blue wire.  Its a negative wire so go to the alarm box and theres pins on the top back of it.  Look in manual if you cant find  what im talking about and move the little pin from right to left and the light output will become negative instead of default positive and it should work.
Posted By: dspjm28
Date Posted: April 22, 2007 at 1:30 PM
All sensors and features I wanted are now working >thank you very much for your assistance.I could not have finished this without your assistance.
