2000 gmc denali door lock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93394
Printed Date: April 18, 2026 at 3:34 AM
Topic: 2000 gmc denali door lock
Posted By: chadhurd
Subject: 2000 gmc denali door lock
Date Posted: April 27, 2007 at 12:47 PM
My boss bought this car from an auction.  The car had an aftermarket alarm but was removed.  The question i have is when i push the lock or the unlock it will only lock.  Had anyone else had this problem.  Also did these cars have a door lock chime?  When i hit the lock or unlock a chime goes off.  Any help will be apreciatied.
Posted By: advancedautosec
Date Posted: May 03, 2007 at 7:30 PM
i dont know about the not unlocking part, but on most newer GMs if you try to lock the door when its opened and key in the ignition it will chime. i guess its supposed to prevent you from locking your keys in the car.
Posted By: nubiannupe
Date Posted: May 05, 2007 at 6:55 PM
Is this problem solely on one door, or do all the doors have this problem?? There's nothing out of the ordinary about the lock system on this truck (type a pos trigger), which 'possibly' eliminates whether or not you pulled something you shouldn't have (bypass module or relay pack). Find the door lock wires (in the door boot) and test each to see if you get anything out of them when you activate the switch. Because it sounds like a switch issue.
As for the chime thing, I think 02 and up were databus, so you should hear the chime.
G. Rick (aka; Tha "R")
**Peter North is my idol***
MECP-Certified 1st Class Installer
