160xv activation
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93561
Printed Date: April 18, 2026 at 2:16 PM
Topic: 160xv activation
Posted By: mobilecustoms
Subject: 160xv activation
Date Posted: May 02, 2007 at 9:39 PM
i have a dei viper 160xv on my car and want to start the carw with the factory remote by pressing lock 3 times. I also want to use the remotes that came with it byut press the viper remotes twice to start the car. Is this programmable with the bitwriter? if so- how?
Posted By: enice
Date Posted: May 02, 2007 at 10:38 PM
As far as i know it would control both the remote and WHITE/ blue wire for the pulses equally.  By the way im also in NY(BX)
Posted By: captainzab
Date Posted: May 03, 2007 at 12:51 AM
You can hook up the blue/white wire off the 12pin harness (activation input) to your factory lock wire.
If you change the pulse input (default is at 2) to 3, when you use the viper remote, it will also be 3.
Date Posted: May 03, 2007 at 7:37 AM
that stinks, but ok thanks for the info
