04 ford escape remote programming
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93607
Printed Date: May 16, 2026 at 11:58 AM
Topic: 04 ford escape remote programming
Posted By: desh187
Subject: 04 ford escape remote programming
Date Posted: May 03, 2007 at 9:02 PM
Does anyone know how to program oem style remote
on 2005 Ford Escape.This is not the factory remotes but the aftermarket look alike made by codealarm for Ford and the vehicle has an alarm/autostart combo.
Thanks.
Posted By: mobilecustoms
Date Posted: May 04, 2007 at 11:47 AM
Adding Remote Controls to Your System:
The system has the ability to operate from up to eight (8) remote controls. Follow
these instructions to add a remote control to your system.
1. Make sure the security system is disarmed and the ignition is off.
2. Open the driver’s door.
3. Turn vehicle ignition on.
4. Press and hold programming/override button under the instrument panel.
After 15 seconds, the horn will chirp three (3) times. This indicates that the unit
has entered the remote control programming mode.
5. Release the programming/override button.
6. Press the button on the remote control to be programmed.
The siren or horn will sound once, indicating that the system has “learned” that
remote control.
7. Repeat step 6 for any additional remote controls.
8. Turn the vehicle ignition off to exit the programming mode. Test all remote controls
to ensure that they work properly.
