2000 acura 1.6 el
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93701
Printed Date: April 23, 2026 at 8:33 AM
Topic: 2000 acura 1.6 el
Posted By: mbsaudio
Subject: 2000 acura 1.6 el
Date Posted: May 07, 2007 at 9:26 PM
Need info for this vehicle. Only in Canada and not quite the same as the Civic. This car has diff. modules for trunk, alarm and keyless apparently.
Posted By: level12
Date Posted: May 08, 2007 at 12:52 AM
I've done a couple of these, Similar to the 99-00 civic. For the alarm/trunk module you can find it under the driver's seat. it's been a while, i'll have to check my notes if you need more info, but you should be fine using most of the civic info.
------------- Never argue with an Idiot, they will bring you down to their level and beat with you with experience.
Posted By: mbsaudio
Date Posted: May 08, 2007 at 6:32 AM
Thanks level12(?) Heard that there was some sort of module under the seat. Anyone have the full diagram I would really appreciate it.
Posted By: KarTuneMan
Date Posted: May 08, 2007 at 8:19 AM
Is this just a Canada thing....wiremagic, and astrochart show this year civic having the keyless and such, behind the radio...in the radio harness? | LOCK | GREEN / WHITE | In driver's kickpanel or | - | | | | Factory alarm harness located behind radio. If car is equipped with factory alarm, see our SECURITY diagram. |
| | UNLOCK | GREEN/ orange | In driver's kickpanel or | - | | | | Factory alarm harness located behind radio. If car is equipped with factory alarm, see our SECURITY diagram. |
| | DOORPIN | Lt.GREEN/ red | In driver's kickpanel or | - | | | | Factory alarm harness located behind radio. If car is equipped with factory alarm, see our SECURITY diagram. |
| | TRUNK PIN | Blue/black | In driver's kickpanel or | - | | | | Factory alarm harness located behind radio. If car is equipped with factory alarm, see our SECURITY diagram. |
Posted By: thepencil
Date Posted: May 08, 2007 at 8:20 AM
That's correct. The module is under the driver seat, but you don't need to go there. You can get access to all the wire at the driver's kick panel leading to the module. Remove all the panal first, it's a lot easier to do your work. ------------- Be careful whose advice you buy, but be patient with those who supply it.
Date Posted: May 08, 2007 at 8:26 AM
KarTuneMan,
I think it's a Cdn thing. Astro has the correct infomation for this particular vehicle, but not Directed. It's not like the Civic at all which I thought it should be. A bit more work, but not too much more pain. ------------- Be careful whose advice you buy, but be patient with those who supply it.
Posted By: silvercivicsir
Date Posted: May 08, 2007 at 10:00 PM
it's exactly the same as the civic, except the security module is under the front seat. only difference is it doesn't have the security plug near the radio, and the trunk pop is 5 wire at the alarm (under the seat).. besides that it's exactly the same..
