2007 jeep liberty, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93739
Printed Date: May 15, 2026 at 3:14 AM
Topic: 2007 jeep liberty, remote start
Posted By: buck_nekid
Subject: 2007 jeep liberty, remote start
Date Posted: May 08, 2007 at 9:24 PM
Just a quick y/n, is a '07 the same as a '06? No surprises on a remote start?
Posted By: mikvot
Date Posted: May 08, 2007 at 9:35 PM
Looks the same.
12volts
  red (40A), red (40A)
  ignition harness
Starter  lt. blue/red   +   ignition harness
Second Starter  N/A
Ignition  pink/lt. green   +   ignition harness
Second Ignition  N/A
Third Ignition  N/A
Accessory  pink / YELLOW   +   ignition harness
Second Accessory  pink / YELLOW   +   ignition harness
Keysense  PURPLE / tan   -   ign harn or BCM, 26 pin plug, pin 8
Power Lock  tan/dk. blue   -   back of fuse box, top L plug, pin 14
Power Unlock  same as power lock wire
Lock Motor  tan/dk. blue   5wi  back of fuse box, top L plug, pin 6
Unlock Motor  tan/lt. blue   5wi  back of fuse box, top L plug, pin 8
Parking Lights+  do not use, relay rests at gnd
Parking Lights-  pink/red   -   switch or BCM, 22 pin plug, pin 5
Hazards  WHITE/ dk. blue   -   switch or BCM, 26 pin plug, pin 12
Turn Signal(L)  WHITE/ dk. green   +   hazard switch/combination flasher
Turn Signal(R)  WHITE/ orange   +   hazard switch/combination flasher
Reverse Light  WHITE/ gray   +   driver kick, harness to rear
Door Trigger  see notes   -   BCM
Dome Supervision  BLACK/ white or yellow/lt. blue  -   back of fuse box, top L plug, pin 30
Trunk/Hatch Pin  pur/org and pur/yel (glass)   -   DKP or BCM, 26 pin plug, pins 7, 9
Hood Pin  PURPLE / lt. blue   -   pin sw. or BCM, 26 pin plug, pin 6
Trunk/Hatch Release  lt. GREEN / WHITE   -   DKP or BCM, 26 pin plug, pin 17
Power Sliding Door  N/A
Factory Alarm Arm  arms on lock with door open
Factory Alarm Disarm  factory remote only
Disarm No Unlock  with ignition and Sentry Key
Tachometer  NOT RED / orange or pink/gray   ac   any ignition coil or fuel injector
Wait to start
Brake Wire  WHITE/ tan   +   brake pedal switch
Parking Brake  dk. GREEN / WHITE   -   parking brake switch
Horn Trigger  dk. GREEN/ purple   -   horn switch
Memory Seat 1  N/A
Memory Seat 2  N/A
Memory Seat 3  N/A
Date Posted: May 09, 2007 at 12:17 AM
Thanks, looks like the same.
posted_image
