2005 ford taurus door false triggering?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93783
Printed Date: May 14, 2026 at 12:29 PM
Topic: 2005 ford taurus door false triggering?
Posted By: obsessiveracer
Subject: 2005 ford taurus door false triggering?
Date Posted: May 10, 2007 at 12:47 PM
im working on a 2005 ford taurus and i used the directechs printout to find all my wires ever 50 minutes or so the alarm goes off for no apperant reason when i dis arm the alarm which is a autopage rf-315 it says that the door trigger was at fault i used the negative trigger and diode isalated the four wires has any one else had this problem and if so what was the remedy
Play It Till It Hertz, Bag it then drag it
Posted By: enice
Date Posted: May 10, 2007 at 1:09 PM
it could be that the car is shutting down, hence causing a false trigger.  Go to the downloads section on this website and look for DOC 1076
Date Posted: May 10, 2007 at 2:44 PM
ok i did that and it worked no more falseing thanks man
