software/wiring diagrams
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94177
Printed Date: April 18, 2026 at 11:07 PM
Topic: software/wiring diagrams
Posted By: jurb
Subject: software/wiring diagrams
Date Posted: May 23, 2007 at 10:07 AM
I am pretty proficient at installing car audio stuff, but over the next couple months I'm moving into car alarms and door lock actuators (my truck doesn't have power anything). The circuitry seems to be quite a bit more complicated so I'd like to download some software and model the circuits I am going to build before I start. Do you guys know of any good free software downloads for this purpose? Also I need to find the wiring diagram for a 2001 Dodge Ram Extended Cab. Where can I find that?
Just for reference: I am installing a Viper 350HV, and Crimestopper actuators.
I really appreciate any advice.
Posted By: KarTuneMan
Date Posted: May 23, 2007 at 12:03 PM
www.the12volt.com   you'll find evething you need here.
Posted By: thepencil
Date Posted: May 23, 2007 at 12:08 PM
FYI,
DIRECTWIRE™ WIRING INFORMATION - DODGE / RAM PICKUP / 2001 / Remote Start
12volts red and pink/black    +   ignition harness
Starter yellow    +   ignition harness
Second Starter
Ignition dk. blue    +   ignition harness
Second Ignition
Third Ignition
Accessory BLACK/ orange   +   ignition harness
Second Accessory BLACK/ white   +   ignition harness
Keysense
Power Lock ORANGE / purple   5wi driver door harness
Notes: Keyless models use positive trigger for lock, and 5-wire for unlock. Can also find wires at the central timer module to the right side of the steering column, lock is ORANGE / green, unlock is pink/green.
Power Unlock pink/purple   5wi driver door harness
Lock Motor ORANGE / black      driver door harness
Unlock Motor pink/black      driver door harness
Parking Lights+ BLACK / YELLOW      headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow    -   headlight switch or DKP
Notes: To avoid dome delay, use tan for the drivers door and BLACK/ lt. blue for the passenger door. Both wires are located at the central timer module to the right side of the steering column. Use both wires and diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm lt. GREEN/ orange   -   driver door harness
Notes: Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger through a 1.5K (1500) ohm resistor. MUST use relays.
Factory Alarm Disarm same wire
Disarm No Unlock
Tachometer BLACK/ gray      ignition coil
Notes: Diesel tach wire is gray/black. The wire is located on the center of the firewall. There are two black plugs, the wire is in the top plug without the white insert. The tach wire can also be found at the ECM on the passenger side firewall in connector C-1, pin 8.
Wait to start ORANGE / black   -   center of firewall, black plug
Notes: See DirectFax document 1090.
If using the ORANGE / black for wait to start causes a shifting or cruise control problem then use a pulse timer relay instead. Refer to DirectFax 1091 for wiring information.
Brake Wire WHITE/ tan    +   brake pedal switch
Parking Brake
Horn Trigger BLACK/ red    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
