factory arm and disarm 07 accord
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94284
Printed Date: April 19, 2026 at 5:21 AM
Topic: factory arm and disarm 07 accord
Posted By: csnut18
Subject: factory arm and disarm 07 accord
Date Posted: May 27, 2007 at 1:47 PM
Hey guys, I know the factory disarm wire is only inside the drivers door on the 07 accords. My question is, is this wire accessible by taking off only the front panel or is more disassemble required? Also do you have to wire through a molex on this car to do this or is their any other way that you guys recommend? I know this is a popular car so hopefully some people on here would of had to of gone through this already. Thank you in advance.
Posted By: KPierson
Date Posted: May 27, 2007 at 3:26 PM
The wire runs between the key cylinder and the power window switches, so it can be accessed by pulling up the door finisher.  However, you will have to run the wire through the molex connector.  Its a pain, but its the only way to get it done (That I know of).
Kevin Pierson
Posted By: rudydapimp
Date Posted: May 27, 2007 at 4:08 PM
Use the bypass from bypasskits.com.  No need for running wires into the molex. model HODL4. very nice unit. Found out about it on here, love it. have a nice stockpile of them in the bin now!!
Posted By: csnut18
Date Posted: May 27, 2007 at 6:20 PM
Thank you, I am looking into that bypasskit part now.
