viper 5900
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94489
Printed Date: March 25, 2026 at 9:47 AM
Topic: viper 5900
Posted By: creed2k
Subject: viper 5900
Date Posted: June 03, 2007 at 2:44 PM
My car is in the shop right now and they disconnected the battery... i have a few questions about this. Number one will the alarm go off when the battery is reconnected? and number two will i lose any of my settings?
Posted By: captainzab
Date Posted: June 03, 2007 at 10:36 PM
it the alarm was disarmed before the battery was unplugged, then the alarm will not go off when plugged back in.
Settings does not get erased.
Note: You Always Dont Get What You Pay For.
Posted By: creed2k
Date Posted: June 04, 2007 at 12:10 AM
nothing will get erased? like where the RPM is set at for remote start, etc?
Posted By: altytruck
Date Posted: June 04, 2007 at 8:03 PM
nope you should be fine. Besides if it does lose the tach signal its pretty easy to reset. Start car, within 5 seconds press and hold valet until LED lights up constant. Good to go
Posted By: enice
Date Posted: June 04, 2007 at 8:07 PM
Im pretty sure you when you start the car you have to hold the valet switch for 5 secs.  You will hear a click from the alarm and with that you will know that the alarm tach wire has been programmed.
Posted By: creed2k
Date Posted: June 05, 2007 at 6:34 AM
Yeah i know how to do it i just didnt want to set it again if i didnt have to
Posted By: dswift
Date Posted: June 05, 2007 at 11:28 AM
yeah most control modules keep memory of the last tach that was programmed.
"dont ground out!"
Posted By: creed2k
Date Posted: June 05, 2007 at 5:40 PM
ok great, thanks guys!
