2005 dodge durango door pin trouble
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94497
Printed Date: March 25, 2026 at 2:37 PM
Topic: 2005 dodge durango door pin trouble
Posted By: fairladyz
Subject: 2005 dodge durango door pin trouble
Date Posted: June 03, 2007 at 8:12 PM
I am having trouble connecting my alarm to the door triggers of my Durango. When I connected them, after arming, about 30-60 sec. later the alarm goes off thinking that a door is open. I tested the wires and with the door open it reads 6.6 mv. With the door closed and the domelight on it will read 11.5 v. However, when the domelight goes out, the voltage drops to .750 v. If any one can help, I would appreciate it.
Posted By: rudydapimp
Date Posted: June 03, 2007 at 8:25 PM
what equipment are you using? some units have a programable dome delay circuit.
Posted By: enice
Date Posted: June 03, 2007 at 9:02 PM
Refer to DirectFax 1076 for wiring information.  Your vehicle systems shut down therefore causing the false alarm.  Look for that doc on this website and it will solve your problem.
Date Posted: June 04, 2007 at 9:42 PM
I have read the direct Fax 1076. Thank You so much, I have been trying to fix this problem for a few weeks. Do you know if I can put the diodes in-line right before I connect the alarm input wires?
Date Posted: June 04, 2007 at 9:45 PM
Sorry rudydapump it is not the dome light circuit, by enabling the dome light delay feature the door triggers are just bypassed. The alarm thinks the car is being armed with the doors open, causing it to bypass them.
Posted By: enice
Date Posted: June 04, 2007 at 10:00 PM
There is a reason why there is 2 diodes in line with the BCM.  One on the BCM and the other on the input wire.
