2000 chevy impala door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94504
Printed Date: March 25, 2026 at 4:06 PM
Topic: 2000 chevy impala door locks
Posted By: cashmoney
Subject: 2000 chevy impala door locks
Date Posted: June 04, 2007 at 8:01 AM
I have  a 2000 impala, trying to install a remote start using factory keyless entry , but was unable catch a negative pulse from the lock button on the remote. I have done plenty of vehicles like this, but this was the first to get me. Has anyone done this vehicle before and suggestions about this situation?
cashmoney
Posted By: Big Dog
Date Posted: June 04, 2007 at 2:58 PM
Lock and unlock use the same wire. It's an ORANGE / black wire in a gray 24 pin plug at the BCM.
Lock requires a negative trigger with a 470 ohm resistor in-line.    Unlock is negative trigger.    Must use relays.
The BCM is located above the brake pedal. It is a plastic box with three plugs that face the firewall.
Prepare your future. It wasn't the lack of stones that killed the stone age.
