viper 350 lock/unlock confirmation chirps
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94534
Printed Date: May 09, 2026 at 4:57 PM
Topic: viper 350 lock/unlock confirmation chirps
Posted By: DracosIgnis
Subject: viper 350 lock/unlock confirmation chirps
Date Posted: June 05, 2007 at 10:29 AM
One final question I’m hoping someone can answer.  I’ve had Viper alarms for a good 8 years now, and I’ve never had one that continues to
give confirmation chips each time I press the button, meaning, the alarms seems to know what state it's in.  As in:
Once it’s unlocked, it would basically do nothing if I pressed the unlock button again.
Same for the lock function, after the 5 or 10 seconds to miss the progressive arming, hitting the lock button would do nothing.
This Viper 350 just starts over if I hit the lock button again, chirp and I can even go through the progressive arming stages.
After talking with the installer, he mentioned that it is functionally properly and it does this because I have the optional 4 button remotes.  Does this sound right?
Posted By: advancedautosec
Date Posted: June 07, 2007 at 3:10 PM
sounds about right to me, all mine do the same. you can also disable different sensors by pushing the lock button two or more times after arming the system.
