dodge magnum chdl7 pk2
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94675
Printed Date: May 08, 2026 at 3:22 AM
Topic: dodge magnum chdl7 pk2
Posted By: Bigkevin20
Subject: dodge magnum chdl7 pk2
Date Posted: June 10, 2007 at 6:26 PM
I am still stuck and can not figure this thing out. I got every thing working now except for the remote start. Please some body help me!!! I have been reading all the diagrams. Now I can get the remote start to act like its going to start. It turns on the acc radio / blower then I hear the alarm click like its trying to start but the ign never turns over. It will try this twice then it quits.
This is how I have the wires on the CHDL7-PK2
Brown to Remote start - output on alarm remote starter
Violet to    ORANGE / White data wire Skim Module
Pink/White to Violet/Brown ign harness
Pink to Pink/green ign harness
The rest of the wires are correct and dont need to be mentioned.
Now its the Pink wire that I think is the problem. I have tried it not connected, I have tried it connected. Also with a 1K resistor to ground and the pink while its conected to the pink/green. Like I said It acts like its going to start but the ign never kicks over. And I had no problem prgraming the bypass. Please help!!!
Posted By: enice
Date Posted: June 10, 2007 at 6:52 PM
Looking at diagram and mentions it needs to be connected to the vehicle and rcs starter wires
Posted By: fkelsey
Date Posted: June 11, 2007 at 8:02 PM
Have you tried it with the key in the ignition? I have had a couple that I did not have enough wraps around the key cylinder. Also I pull the board out of the ignition module to make sure I get the transponder close enough during programming.
