viper aux output
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94852
Printed Date: May 11, 2026 at 6:56 PM
Topic: viper aux output
Posted By: jurb
Subject: viper aux output
Date Posted: June 16, 2007 at 3:59 PM
I just finished installing a 350HV. I want to use the aux output to turn on my head lights. Do I need to use a relay to do this?
Posted By: enice
Date Posted: June 16, 2007 at 5:02 PM
Posted By: KarTuneMan
Date Posted: June 16, 2007 at 5:36 PM
What kind of vehicle? This does make a diff. Some you will need to use a relay....others you will not!
Posted By: jurb
Date Posted: June 16, 2007 at 7:12 PM
Dodge RAM 1500, 2001. From the Hayne's manual, the wire that controls the head lights is light green. When I tested that wire it went from +12V to ground when I turn the lights on. So I am wondering if I need to connect the output from the alarm to a relay that switches to ground, or just use the output from the alarm itself? The output is -200mA. I really appreciate the help.
Posted By: jurb
Date Posted: June 16, 2007 at 8:13 PM
 This is what I was thinking.
Posted By: peterubers
Date Posted: June 17, 2007 at 10:55 PM
Um, I can't recall for sure, but don't think it's that simple: I know the dodge/chrysler's need to see a certain resistance in the headlight wire to turn on: Check this link: https://www.the12volt.com/installbay/forum_posts.asp?tid=67105&KW=ram+headlight I'm not sure if the 2001 is different .. if the 2001 is a simple 12 volt + wire for turning the headlights on, then wiring as follows: 85: 12 volts fused (+) 86: aux output from brain (-) 87: to headlight wire on Dodge Ram(+) 30: 12 volts fused(+) ------------- The search function is your friend.
Posted By: enice
Date Posted: June 17, 2007 at 11:10 PM
According to DEI it is a light green wire at the light switch. Victory technology states that it is a GREEN/ black wire at the same switch. Post which is right. By the way, DEI states that this wire needs a high current ground so yes you do need a relay. Either way both are (-) triggers.
Posted By: jurb
Date Posted: June 18, 2007 at 9:40 AM
So I got it to work using a SPST relay from Radio Shack. For a 2001 Dodge Ram it is a light green wire that comes out of the headlight switch, it's pretty easy to find once you unscrew the switch from the dash, it goes from 12V+ to 0 when the switch is turned on. The wiring of the relay was:
85: 12V+
86: Trigger from alarm
30: Ground
87: Light green headlight wire
Thanks for the help, this site is great.
