power door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94871
Printed Date: May 11, 2026 at 8:38 AM
Topic: power door locks
Posted By: fr0z3n
Subject: power door locks
Date Posted: June 17, 2007 at 5:42 PM
I installed 2 power door locks in my 92 civic hatch eg, I have them wired up properly to the unlock but I can't figure out why they won't lock. I installed the 2 relays but I just need to know what wires off the alarm will lock/unlock the doors.
According to the wiring instructions
green = (-) unlock output which is correct and is working but
brown = (-) lock output which isn't working afaik
any help is appreciated because I wanna finish this I've had my door panels off for a week and I've been loafting
Posted By: fr0z3n
Date Posted: June 17, 2007 at 5:43 PM
I don't see an edit button but I forgot to state it's the prostart ct-5460
Posted By: peterubers
Date Posted: June 17, 2007 at 5:50 PM
is the brown wire dropping to ground (0 vdc) when you press the lock button on the keyfob?
The search function is your friend.
Posted By: fr0z3n
Date Posted: June 17, 2007 at 5:58 PM
no.
The green grounds when I press unlock, the brown doesn't ground for lock or unlock
Date Posted: June 17, 2007 at 6:14 PM
hmm... are there any blue wires off the alarm module?
sounds like the brown wire isn't doing what it should
Posted By: fr0z3n
Date Posted: June 17, 2007 at 6:18 PM
blue = trunk/ aux3 (-)
Date Posted: June 17, 2007 at 6:29 PM
if the brown isn't working, you may have to use blue as your unlock wire.
Posted By: fr0z3n
Date Posted: June 17, 2007 at 8:31 PM
it already unlocks.... the problem was locking.. I hooked it up to the white brown wire
WHITE/ brown = (-) rearm output
Date Posted: June 17, 2007 at 8:35 PM
well done
