in opel corsa c of 2001
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94983
Printed Date: May 09, 2026 at 10:12 PM
Topic: in opel corsa c of 2001
Posted By: daniboy
Subject: in opel corsa c of 2001
Date Posted: June 21, 2007 at 12:52 PM
i need to know here is the comfort module for rooling-up windows and what is  the pin to apply the pulse to do it..
Posted By: enice
Date Posted: June 21, 2007 at 1:25 PM
Im not sure what vehicle your working on but usually pulsing the lock wire in the door  and then a continuous pulse will roll window up.  Same goes for windows down.  Pulsing unlock once and then continous pulse will also roll windowns down.
Posted By: daniboy
Date Posted: June 22, 2007 at 8:30 AM
hi..
i nown that in comfort module have 1 pin that he aplly a pulse to rolling up windows...but i dont nown here is the module and the pin...
Posted By: enice
Date Posted: June 22, 2007 at 9:40 AM
You may go in the actual driver door.  with a multimeter put the key inside the key cylinder and turn while testing wires in that door.  If it gives you a read then it could be the actual wires for it.
