who use can bus kit?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95020
Printed Date: May 09, 2026 at 10:16 AM
Topic: who use can bus kit?
Posted By: rookie_911
Subject: who use can bus kit?
Date Posted: June 22, 2007 at 1:28 PM
Hi,
I'm lost !!!!
I have 4 choices to use in my 2003 Volkswagen Jetta,
I will install a remotestarter with alarm but I'm so confused ...
Please help, what is advantage/disadvantage for all units.
BYBASSKIT with XK01
https://www.bypasskit.com/product.aspx?prodid=XK01
FORTIN with CAN-SL2
https://ifar.ca/en/products/bypass_kits/can-sl2/?year=2003&make=16&model=2715
DEI-CAN with CAN-1
https://www.drdetailshop.com/can1.htm
IDATALINK with ADS-AL(DL)-CA
https://www.idatalink.ca/viewprod.asp?carid=2008&catid=3&pid=31&type=car
Thanks,
Rookie
Posted By: dswift
Date Posted: June 22, 2007 at 2:32 PM
CANSL2i and a Universal Transponder box.
Word
------------- "dont ground out!"
Date Posted: June 26, 2007 at 7:56 AM
What is advantage/disadvantage compared to the others ?
Posted By: dswift
Date Posted: June 26, 2007 at 10:30 AM
Well they both do the same jobs. Its basically your choice for price. Its a can bus kit. Meaning directs traffic for data. So they all have the same job. if you had a nissan i would do a cansl2i becuase it does transponder for nissans as well as trunk,lock,unlock, ect... But for your VW platform. It does the same as the i data link as well.
