door trigger, 2001 dodge ram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95157
Printed Date: May 06, 2026 at 6:01 AM
Topic: door trigger, 2001 dodge ram
Posted By: jurb
Subject: door trigger, 2001 dodge ram
Date Posted: June 27, 2007 at 7:37 AM
Finished my installation and everything was cool for a couple weeks. I went back to rerun my wires and organize them a bit better, and now all of a sudden my door trigger is being tripped. Obviously I am not riding around with my doors open but somehow that wire must be seeing ground. I think it must be: A) the wire from one of my triggers might be damaged and touching metal, B) the diode from the door is failing (is that possible?0 are there other possibilities that I could be missing? Thanks for the help in advance.
Posted By: KarTuneMan
Date Posted: June 27, 2007 at 9:44 AM
Worked fine for a couple weeks? Then started triggering .....with your truck rolling down the raod?
What did you use for door trigger? And why would it trigger while driving, it shouldn't be "armed" There are 2 possible places to get door trigger. At the keyless
module, OR at an under dash light.
What did you install ? (what type of unit)
Posted By: jurb
Date Posted: June 27, 2007 at 11:48 AM
I should have been more specific, I installed a Viper 350HV, and when I say door trigger being tripped what I mean to say is that my dome light stays on as if my door is open. When I arm the alarm it makes 2 deeps as if the door is open. What do you think?
Date Posted: June 27, 2007 at 3:01 PM
Dome light delay maybe... ? If the dome light takes a bit of time to turn off...the alarm will think the door is open.
I believe the unit should be able to be programed to ignore the dome upon arming? Someone else will chime in on this I'm sure.
Posted By: enice
Date Posted: June 27, 2007 at 5:44 PM
that is correct Kartuneman.  This is a feature on the alarm.  Its called "door sensor bypass chirp". Look up the manual and turn off the feature
Posted By: jurb
Date Posted: June 27, 2007 at 6:52 PM
Thanks for the responses guys, but I didn't hook up the dome supervision output for the alarm so unless I am missing something it can't be the dome light relay. I am going to test the wires here shortly and see what I can find
Date Posted: June 27, 2007 at 7:46 PM
It has nothing to do with domelight supervision,  domelight supervision simply turns the domelight ONwhen you disarm/unlock. Just read about programing the dome delay OUT!
Posted By: enice
Date Posted: June 27, 2007 at 7:53 PM
If you used the yellow wire as a door trigger it will give you a chirp.  Only way to stop this is to go an get individual door triggers or turn off door sensor bypass.
Posted By: jurb
Date Posted: June 28, 2007 at 1:43 PM
again thanks, it turns out my passenger door pin switch got stuck.  what is the dome delay?  thats not standard in all cars is it?
Date Posted: June 28, 2007 at 4:09 PM
Dome delay is.... after you close the door, it takes up to 30 seconds for the dome light to shut off/down. Some alarms, when you lock and arm, see the dome being on, means the door is open, means someone is breaking in, means it's time to sound the alarm.......posted_image
Glad to hear you got er done!
