92 bmw 525i
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95189
Printed Date: April 08, 2026 at 4:01 PM
Topic: 92 bmw 525i
Posted By: old timer
Subject: 92 bmw 525i
Date Posted: June 28, 2007 at 5:43 PM
Guys
got a 525I that keeps popping fuses. power locks 7.5 and windows 7.5. it has keyless entry with the alarm. i installed this 4yrs ago we did have this problem until a month ago. problem: when arming the alarm or disarming it pops the fuses. it's on a some time bases. I have went threw and check all my wiring for shorts I come up clean. have any of you guys ran across this problem with theses cars? if so what didi you do.
The beat goes on
with Smoke-n-Jazz
catering.
Where pork,chicken,beef and Jazz form a great Quartet
in sac town
Posted By: KarTuneMan
Date Posted: June 28, 2007 at 10:18 PM
So it's the "factory" fuses for windows and locks that are blowing?
Date Posted: June 29, 2007 at 10:07 AM
yes the factory 7.5s are popping. funny thing is we didin't have this problem before. could it be the factory door lock relays arcing or sticking? aftermarket relays look good I have checked them already. this car is becoming a pain.
The beat goes on
with Smoke-n-Jazz
catering.
in sac town
Date Posted: June 29, 2007 at 12:55 PM
BMW = pain.....
relays for locks?
Date Posted: June 29, 2007 at 8:06 PM
yes relays to pulse the door locks. pos trig. like I said it has been working fine until about a month or so. now he called to tell me that the windsheild wipers are going when the fuses blow while driving but when he opens the driver door it stops. I don't no where to start looking on this one. and I don't think it's an alarm problem do you, where would you go on this one.
The beat goes on
with Smoke-n-Jazz
catering.
in sac town
Posted By: howie ll
Date Posted: July 01, 2007 at 7:13 PM
I think you've got a bad component or ground on the car's electrics, also lift up back seat and check voltage accross battery terminals with a DMM when you start engine it should be about 13.8v+ after about 15 secs running,  if over 14.5 your alternater needs rectification(I had to do that one), also look at control module at other side to battery, should be clean and DRY.
Posted By: INSTALLER_MSS
Date Posted: July 01, 2007 at 9:36 PM
BMW, 5 SERIES, 1992, Power Lock
Do not operate locks by remote with door open or deadbolted to prevent possible damage to servos.
Anti-theft plug or module located under rear seat on passenger side. Door wires also found at general module under rear seat on drivers side. Be careful handling this module, as rotating it can cause underseat grommets to suck out, allowing eventual water damage to the electrical system. Domelight supervision wire BROWN / red at anti-theft plug.
"If a man made it, another can modify it...it just takes some thinking."
"If you ask questions, you're a fool for 5 minutes; if you don't, you're a fool for a lifetime."
Date Posted: July 02, 2007 at 12:38 AM
Thanks Guys.
The beat goes on
with Smoke-n-Jazz
catering.
in sac town
