1998 lincoln nav key override sl2
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95207
Printed Date: April 08, 2026 at 9:02 AM
Topic: 1998 lincoln nav key override sl2
Posted By: ceasar326
Subject: 1998 lincoln nav key override sl2
Date Posted: June 29, 2007 at 10:15 AM
Im installing a crimestopper alarm and remote start on to a 98 lincoln navigator. As a bypass module am using key-override-sl2. This is the first time i install this module so i dont have that much experiance on this. Ive connected all the wires to the car, alarm and module. But the module would program. Does any body know what would be my colors for RX an TX in and outputs from the factory bypass module.
Posted By: enice
Date Posted: June 29, 2007 at 3:16 PM
well its a four pin plug at the key cylinder.  what you can do is find your ign wire first.  With a dmm connect your black lead to ground and the red to a wire in that plug that has power when turned on to ign.  IF you find that wire then the wire to its left(if its the last wire on the plug) is ground.  The wire on the opposite side is the RX wire and the wire next that one is TX
Pin 1-Ground
Pin 2-ign
Pin 3-RX
Pin 4-TX
