2003 Tiburon Diagram ?? (Jeff !)
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9537
Printed Date: May 06, 2026 at 3:13 PM
Topic: 2003 Tiburon Diagram ?? (Jeff !)
Posted By: radsta
Subject: 2003 Tiburon Diagram ?? (Jeff !)
Date Posted: February 15, 2003 at 7:23 AM
Anyone have info on the doorlocks for this vehicle ? I'm doing remote start today, ANY information appreciated , Thanks- Steve
Posted By: Haku
Date Posted: February 15, 2003 at 10:08 AM
12V|red |+ |ignition harness | | STARTER|white |+ |ignition harness | | IGNITION|red |+ |ignition harness | | ACCESSORY|pink |+ |ignition harness | | SECOND ACCESSORY|orange |+ |ignition harness | | POWER LOCK|yellow or blue *1 |F |12 pin plug @ BCM *2 | | POWER UNLOCK|same wire | | | | LOCK MOTOR|green | |22 pin plug @ BCM *2 | | UNLOCK MOTOR|GREEN/ black | |22 pin plug @ BCM *2 | | DISARM DEFEAT|no progressive unlck| | | | PARKING LIGHTS +|pnk/blk(L),grn/org(R| |22 pin plug @ BCM *2 | | PARKING LIGHTS -|blue/orange | |headlight switch | | HEADLIGHTS|brown |- |headlight switch | | DOOR TRIGGER|yellow |- |22 pin plug @ BCM *2 | | DOME SUPERVISION|use door trigger | | | | TRUNK/HATCH PIN|GREEN/ black |- |12 pin plug @ BCM *2 | | HOOD PIN|GREEN/ orange |- |23 pin plug in pass. kick | |TRNK/HTCH RELEASE|blue |+ |driver kick panel | | FCTRY ALARM ARM| | | | |FCTRY ALRM DISARM| | | | | DISARM NO UNLOCK| | | | | TACHOMETER|white | |23 pin plug in pass. kick | | SPEED SENSE|brown | |data link connector *3 | | BRAKE WIRE|white |+ |brake pedal switch | | HORN TRIGGER|GREEN/ black |- |steering column | | WIPERS|green (L), gray (H) |+ |steering column | | LF WINDOW UP/DN|brown - orange |A |driver window switch | | RF WINDOW UP/DN|yellow - pink |A |driver kick panel | | SUN RF OPN/CLOSE| | | | | SUN ROOF LIMIT| | | | | RADIO 12V|red |+ |radio | | RADIO GROUND|black |- |radio | | RADIO SWITCH|yellow |+ |radio | | RADIO ILLUMINATE|pink/black |+ |radio | | LF SPEAKER|white - brown | |radio or amplifier *4 | | RF SPEAKER|black - yellow | |radio or amplifier *4 | | LR SPEAKER|blue - red | |radio or amplifier *4 | | RR SPEAKER|green - orange | |radio or amplifier *4 | Notes: NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555U to bypass. *1 The yellow wire will test when when moving the driver lock knob, the blue wire will test when moving the passenger lock knob. *2 The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash. *3 The data link connector is under the driver side dash in the fuse box opening. *4 If equipped, the amplifier is behind the left quarter trim panel below the LR speaker. ------------- Hak
Siemens Autostart
Posted By: radsta
Date Posted: February 15, 2003 at 10:14 AM
Haku- thanks for the response- specifically, how can I control the lock/unlock ? Note says F, what type of system or values ? thanks again, Steve
Posted By: Haku
Date Posted: February 15, 2003 at 10:20 AM
Give me your email, and I will send the diagram. Its not very clear, but hope it helps. ------------- Hak
Siemens Autostart
Posted By: radsta
Date Posted: February 15, 2003 at 10:33 AM
Hak- please send to radsta@aol.com it looks like switching gound is the answer ? Thanks, Steve
Posted By: Haku
Date Posted: February 15, 2003 at 10:43 AM
On its way, print the diagram out, you can read it better, or zoom in on it. ------------- Hak
Siemens Autostart
Posted By: radsta
Date Posted: February 15, 2003 at 11:23 AM
Got it- works perfect ! The factory alarm is annoying- doesn't seem to be any disarm input, oh well.... thanks again , Steve
