remote indicating sensors went off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95396
Printed Date: April 06, 2026 at 2:12 PM
Topic: remote indicating sensors went off
Posted By: zzachattack2
Subject: remote indicating sensors went off
Date Posted: July 06, 2007 at 7:54 PM
i have a viper 791xv installed in my 2000 jeep grand cherokee. i came across an extra shock sensor to install and a glass breakage sensor. the glass breakage sensor came with a wiring harness to easily plug-in along with the standard shock sensor. so there is a shock sensor on zone 2 and glass breakage sensor on zone 4 of that input. i chose to install the output of the extra shock sensor on the blue wire of the main wiring harness which also happens to be zone 4.
now whenever i unlock my car from the remote it displays that a sensor on zone 2, the trunk(does this mean the blue wire?), AND the door triggers were ALL set off. why is this? did i forget to diode isolate something?
the glass breakage sensor and the first shock sensor are wired so no diode is needed (as described in the viper installation manual) and i don't see any reason to need a diode and the blue input wire. so anybody have any idea whats going on?
Date Posted: July 06, 2007 at 7:56 PM
the blue wire is zone 1 not 4 sorry.
Posted By: enice
Date Posted: July 06, 2007 at 8:46 PM
does your led stay on even after disarm?
Date Posted: July 07, 2007 at 1:12 AM
im not sure i'll have to look. however for some reason tonight it stopped doing this alltogether. right after i remote started it for the first time since. hmmm.
