door lock actuator w/clifford alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95803
Printed Date: April 19, 2026 at 7:01 AM
Topic: door lock actuator w/clifford alarm
Posted By: blkb3
Subject: door lock actuator w/clifford alarm
Date Posted: July 21, 2007 at 2:59 PM
I have a Clifford matrix rsx3.2 and im trying to hook up aftermarket doorlock actuators. I have the 451m relay but im not sure if thats the correct way to wire this specific brain. ive been reading these forums fo the past 2 hours......any help will be greatly appreciated.
thanks
Posted By: howie ll
Date Posted: July 22, 2007 at 8:19 AM
If matrix has the following wires in its loom you won't need a 451:- BROWN / black, WHITE/ black to ground, blue/black to motor unlock, GREEN/ black to motor lock, purple and PURPLE / black via fuse to 12v+ perm. If only green  and blue, plug in 451, using same colours. Use 5-7.5 amp fuse per each motor.
