2008 ford f250, alarm, keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96103
Printed Date: April 22, 2026 at 1:12 PM
Topic: 2008 ford f250, alarm, keyless entry
Posted By: tintzone
Subject: 2008 ford f250, alarm, keyless entry
Date Posted: August 01, 2007 at 4:28 PM
Hi I have to put a keyless entry on a friends truck 08 Ford F250 anybody know the wire colors and locations...
Posted By: mikvot
Date Posted: August 01, 2007 at 7:52 PM
12volts
  blue/red (x2)(common 20A)
  ignition harness
Starter  blue/white   +   ignition harness
Second Starter  N/A
Ignition  WHITE/ orange   +   ignition harness
Second Ignition  N/A
Third Ignition  N/A
Accessory  BROWN / yellow   +   ignition harness
Second Accessory  PURPLE / green   +   ignition harness
Keysense  blue/lt. gray   +   ignition harness
Power Lock  blue/lt. green   -   driver kick, door harness
Power Unlock  yellow/purple   -   driver kick, door harness
Lock Motor
Unlock Motor  PURPLE / gray   5wi  driver kick, door harness
Parking Lights+  PURPLE / white   +   SJB, conn. D, pin 20
Parking Lights-  gray   -   headlight switch
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light  GREEN/ brown   +   harness to rear
Door Trigger  see notes   -   each kick or SJB, conn. C
Dome Supervision  yellow/gray   +   SJB, conn. A
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer  blue/white   ac   PCM or Customer Access Point
Wait to start  see DirectFax document 1091
Brake Wire  PURPLE / white   +   brake pedal switch
Parking Brake  WHITE/ purple   -   switch or SJB, conn. C, pin 1
Horn Trigger  yellow/red   -   horn switch
Memory Seat 1  PURPLE / white   -   driver kick, door harness
Memory Seat 2  yellow   -   driver kick, door harness
Memory Seat 3     -
