can-sl, disarm before remote start?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96207
Printed Date: April 12, 2026 at 1:25 PM
Topic: can-sl, disarm before remote start?
Posted By: peterubers
Subject: can-sl, disarm before remote start?
Date Posted: August 06, 2007 at 4:25 PM
I notice there are no inputs for DISARM on the CAN-SL wiring, so my question is does this module send a disarm signal via the databus factory wire prior to remote starting (b/c I do notice there is an input for ground-while-running on the CAN-SL).
The search function is your friend.
Posted By: enice
Date Posted: August 06, 2007 at 5:57 PM
the CAN-SL disarms the factory alarm with the ground while running input and or unlock... this is basically the same way the other companies like Trilogix have it.
Date Posted: August 06, 2007 at 6:29 PM
So, just so i understand 100%, with remote start -- will it unlock -- r/s -- re-lock?  Or will it disarm (doors remain locked) -- r/s?
Posted By: enice
Date Posted: August 07, 2007 at 12:22 AM
As far as i know it will just disarm the factory alarm only(no unlock).  If you want a 100 percent correct answer you can go to https://bypasskits.fortinautoradio.com/en/ and create an account.  After creating an account you can post a question to the makers of the bypass and you will get an answer.
Date Posted: August 10, 2007 at 5:03 PM
enice -- good call, this is my reply email from fortin:
Dear Customerj,
CAN-SL will disarm the TL's factory alarm before remote-starting (with ground-out), with no unlocking of the doors before starting.
Regards,
Jonathan
